Need tires in the upcoming months, Size recomendations? - JeepForum.com
post #1 of 18 Old 08-04-2004, 06:50 AM Thread Starter
spankey
I am in need of replacing my tires on my 96 ZJ. Right now it has the michelin 235/75/15 right now.. My book stated a 225 size tire..
I was thinking about the BF goodrich either all terrain TA or the mud terrain...
The Jeep is NOT lifted.. But there seems to be alot of body clearance, at least as what I can tell.. Can I go with a larger tire and will this affect my stock setup.. I am reading about people lifting thier jeeps and having to do all kinds of stuff like differentials and what not?
I want a nice wide beefier tire but want to stay with the stock deep dish type 5 star rims that are on the jeep...If you know what rims I mean. I think they are only 7 inch rims.. Whats the safest widest tire I can fit on these rims without tire rub and without messing up my suspension?
Can anyone offer me some insight?
Thanks
Spankey
spankey is offline
post #2 of 18 Old 08-04-2004, 12:50 PM
Meerkat
Spankey,
The largest stock tire for your Jeep is the 245/70R15.
This came from the factory on 96 Laredo's with the Up Country suspension.
Here's something to think about:
the OEM 225/75 tire=
tread width - 168.75mm
sidewall - 56.25mm
the aftermarket 235/75 you have now=
tread width - 176.25mm
sidewall - 58.75mm
the optional OEM 245/70 tire=
tread width - 171.5mm
sidewall - 73.5mm
So, if you want to fill the wheelwell, the 245 looks like the way to go, but if you want more tread width, the 235's you are accustomed to appear to be the ticket. Not to mention the shorter sidewall will induce less body roll in turns.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 18 Old 08-04-2004, 07:50 PM
my95yj
my 245/70/16's Dueler AT REVO's will soon be on the market, where are you located?
95 YJ
my95yj is offline
post #4 of 18 Old 08-04-2004, 08:36 PM
IN99WJ
Check out the Tire Rack web site. They have customer surveys on various brands and models of tires. I have Yokohama Geolanders on my WJ that I bought in March. I have put 10,000 miles on them and they don't appear to have worn at all. They are one of the highest rated tires at Tire Rack and are pretty reasonable priced.
IN99WJ is offline
post #5 of 18 Old 08-04-2004, 09:19 PM
Rescue9
I've got 255/70/16's on mine, and haven't rubbed once. I don't have disco's though. Keep that in mind.
Rescue9 is offline
post #6 of 18 Old 08-04-2004, 10:09 PM
LBX2G
I ran 265/70 on mine before the 20s.
LBX2G is offline
post #7 of 18 Old 08-04-2004, 10:49 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You can run 30 x 9.50 15s are the largest you can run without rubbing.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 18 Old 08-05-2004, 05:07 AM Thread Starter
spankey
Thanks all-
I am from eastern Pa.. But I believe that I will keep the 235's on there. They are already there so why change it. But I am looking at the BFG AT Ko's.
My mother inlaw works for a tire chain and can get me a discount.. The BFG's they stock.. The Bridgestones they have to order so I am going to most likely go with the BFGs...
I read that the MUD terrains are horrible on the road.. So seeing how I am only going to be off road about twice a year.. The AT's should be ok....
But again.. Thanks for your ideas and info...
Spankey
spankey is offline
post #9 of 18 Old 08-05-2004, 08:53 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You drive a jeep. Mts are butter on the road.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #10 of 18 Old 08-08-2004, 11:15 PM
quicksilver97
so the largest you can go on the stock 15 inch wheel is a 30x9.5r15? i thought i had seen a jeep just like mine with my same wheels and he had 31x10.5 15 on there. i didnt get to talk to him i just saw it one day.
how much will your speedo be off with tires like that?
quicksilver97 is offline
post #11 of 18 Old 08-09-2004, 04:06 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, you can rub 31s if you want the tires to rub like WT everytime you turn.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #12 of 18 Old 08-10-2004, 11:32 PM
quicksilver97
then i definetly dont need nor do i want that... so when i get new tires in about 3 mths before i leave for college i guess i will be going with some 30x9.5's i suppose
post #13 of 18 Old 08-11-2004, 12:40 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
CLick here to see pics of the 30s on stock Grand.
There is an album with some pics for you.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #14 of 18 Old 08-19-2004, 10:19 AM
quicksilver97
tryed to go to the website but it says i have to be signed in.
can you help me out here.
thanks
post #15 of 18 Old 08-19-2004, 02:14 PM
Meerkat
Hunter
Great album!
What's the story behind 22_22A (the green Jeep with guys hanging off the passenger side and a big ditch under the driver's side)?
Warren
Meerkat is offline
What size tires can i fit? shdybrady19 ZJ Grand Cherokee Forum 4 04-06-2009 07:22 PM
what size tires? asessa ZJ Grand Cherokee Forum 1 07-01-2008 09:35 AM
rim and tires size Q 95ZJ ZJ Grand Cherokee Forum 10 11-16-2007 02:03 PM
What size tires?? redrubi04 ZJ Grand Cherokee Forum 4 09-10-2006 08:00 PM
Upcoming Mods!! njrealtor55 ZJ Grand Cherokee Forum 9 08-31-2005 09:14 PM
