need tire or (TIRES) AND TRANSFER CASE - JeepForum.com
post #1 of 8 Old 09-15-2008, 12:29 PM Thread Starter
briguy55
I Am Wondering What The Biggest Tires I Can Put On My 96 Grand Cherokee Stock. Also Am Looking To Buy A New Transfer Case. My Ring And Pinion Gear Was Bald. I Need To Buy All The Neccessary Parts To Fix It By Winter.
Also If There Are Any Mechanics Out There Wanting To Make Some Side Money? I Live In Chicago. But Would Be Willing To Drive To Anyones House Within A Couple Hours And Help And Learn About Jeeps.
96 Grand Cherokee
96,000 Miles
briguy55 is offline
post #2 of 8 Old 09-15-2008, 12:43 PM
GraKee99
Rapist Wit
GraKee99's Avatar
If off, what is with type the letter of every work in a capital. It is dumb. Second, engine model would help so we know what kind of transfer case you have or if you can just tell us what you have.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 8 Old 09-15-2008, 12:47 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Why do you think you need to replace the tcase? Ring and pinion gears are in the axles.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 8 Old 09-15-2008, 06:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Biggest tires on a zj without rubbing 30x9.50 15s.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 8 Old 09-15-2008, 07:22 PM Thread Starter
briguy55
ok driving my jeep away from the dealer on the highway it made a loud noise and slowed down alot. i found the bad ring and pinion gear and it was all chewed up. I had a mechanic take it out. And right now i have only 2 wheel drive (rear) Then we have to cut all the bearings out to put the tires back on, and my transfer case, is wide open in the front no fluid. I will also need 2 new front axle shafts the outer and the inner i think. obviously im not very handy with cars im only 21 and always had mommy and daddy pay for it but out of college its my responsibility to fix it. I am pretty sure it 3.73 gear ratio. I remember that. . thanks guys
briguy55 is offline
post #6 of 8 Old 09-15-2008, 09:18 PM
elmer_fud
You are talking about the differential, not the Transfer case.
The transfer case is what that determines if you are in 2wd or 4wd and is in the center of the car. It does not have a ring and pinnion.
The cheapest thing to do may be replace the front axle. The axle contains the differential, which is what that is blown
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #7 of 8 Old 09-15-2008, 09:28 PM
newfieZJ
The cheapest thing to do may be replace the front axle. The axle contains the differential, which is what that is blown[/QUOTE]
I`ll second that , especially given your limited knowledge , it would also be the easiest solution .
Get one from a junk yard , preferably hit on the rear or maybe the r/side . Vehicles from accidents have a better chance of being good working parts
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 8 Old 09-15-2008, 10:26 PM Thread Starter
briguy55
thanks guys! anyone have one laying around u know who to contact now!
briguy55 is offline
tire tread and transfer case minimodes89 ZJ Grand Cherokee Forum 15 04-02-2013 01:42 PM
Front end noise: tires, bearing, or transfer case johnnya ZJ Grand Cherokee Forum 1 06-30-2010 07:37 PM
95 transfer case 95grandcher ZJ Grand Cherokee Forum 6 04-19-2008 04:36 PM
ZJ transfer case 94ZJ4x4 ZJ Grand Cherokee Forum 6 07-21-2005 10:21 AM
Tire Deler damage transfer case??? Slightly_Off ZJ Grand Cherokee Forum 1 12-21-2002 12:02 PM
