Need sunroof troubleshooting help! - JeepForum.com
post #1 of 12 Old 09-21-2013, 03:40 PM Thread Starter
Football47
Well decided to re-do my headliner as well as fixing my sunroof motor or whatever is wrong with it. I just got my headliner off and now I'm messing with the sunroof motor. I tested to see if I was getting current from my motor inlet and I'm getting it but not every time that I threw the switch. I notice that the sunroof only really works when it's very hot inside my Jeep but the solders on the board that has the wires that go into it from the sunroof motor look okay. Sorry, don't know the technical name for it... I don't have a way to separately check the motor, so what should I do next? Oh and on a side note, how do you get the sunroof cover off, gotta re-do the material on that too...
Can't beat a Jeep
Football47 is offline
post #2 of 12 Old 09-21-2013, 05:41 PM Thread Starter
Football47
best write-up I found: http://www.jeepforum.com/forum/f13/h...unroof-317929/ Think it's my motor, but how do I get the sunroof cover off?
Can't beat a Jeep
post #3 of 12 Old 09-22-2013, 11:12 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Apply battery voltage directly to the motor. If it turns, it's good of course.
If intermittent, then could be bad solder joint(s) inside the black box (controller). Sometimes they are difficult to spot and it takes a trained eye. I used to do MILSPEC soldering, so I use a 10x lens. That makes it easy to see defects.
no idea how to get the cover off
PM me if you want to send the controller to me to look over. FREE
Just pay ship to and fro.
HighLonesome is offline
post #4 of 12 Old 09-22-2013, 11:58 AM Thread Starter
Football47
Haha thanks, I used an electrical tester to check the switch and I tried the wire shorting method for the switch as well. It worked 90% of the time when I switched it on. I also used a battery on the motor and it didn't run, neither polarity worked. Went to the jy today but didn't find any motors. Btw you do some awesome write-ups, best ones I've ever seen!
Can't beat a Jeep
post #5 of 12 Old 09-22-2013, 12:07 PM
HighLonesome
Thanks!
Polarity doesn't matter on that motor. It should run either way. Sounds like you found the culprit.
post #6 of 12 Old 09-22-2013, 12:21 PM Thread Starter
Football47
Okay so I believe it's the electrical part of my motor and not anything to do with wear and tear on the mechanical parts. I only found a 99 grand cherokee sunroof motor at the jy and it all looked identical to my 98 except the extra plug on the end of the motor with the gear showing. Could I just take the end with the plug and put it on my motor? Trying to find the cheapest way of doing this since you don't see a lot of Zj's with sunroofs.... Is there also anyway of repairing my motor rather than junking it?
Can't beat a Jeep
post #7 of 12 Old 09-22-2013, 12:42 PM
HighLonesome
Don't have your answer except motors can be rebuilt. If you can find someone who knows how to do it and can findthe right parts.
Never heard of one of these motors failing. They really don't get much use.
post #8 of 12 Old 09-22-2013, 06:19 PM Thread Starter
Football47
I think the last owner did work on this Jeep, when I got it the radio, a few dash lights rear windshield motor and all four speakers were not working, shortly after the two driver side door actuators stopped working and the sunroof motor worked on and off. My guess is he did some welding on it without disconnecting the battery? Anyways I'll look around for someone who can rebuild it, and checkout another junkyard since they are pretty cheap at the jy. Thanks for the input, much appreciated.
Can't beat a Jeep
post #9 of 12 Old 09-22-2013, 07:00 PM
Kingr98
2016 JK Wrangler
The cover can come off from above. Open the sunroof all the way and close the sliding cover(forward).
From above, you will see four clips on the sliding cover, two on each side. Using a small screwdriver, pop each clip in and lift up.
The material will peel off. The handle pops off, but it will be fragile.
The edge around the opening just pulls off. I peeled the material off, sanded it as smooth as possible, and painted it a matching color.
Kingr98 is offline
post #10 of 12 Old 09-22-2013, 09:59 PM Thread Starter
Football47
Awesome, because I can do this last. Thanks man! I was thinking about just leaving it but i think I may just re-do this as well.
Can't beat a Jeep
post #11 of 12 Old 09-23-2013, 05:03 AM
Kingr98
2016 JK Wrangler
You need to redo it to match or it will look like crap. And the sunshade is very easy.
If you want to get really industrious, I have a thread on this forum on how to re-upholster your sun visors..
http://www.jeepforum.com/forum/f13/h...-post-1471837/
Kingr98 is offline
post #12 of 12 Old 10-16-2013, 04:11 PM
Eds97ZJ
Hey Football, LOL Can I get a pic of where the motor is located? I'm having same issue but don't want to remove my HL. Thought maybe I could cut out a section to work on motor. So if I use a heat gun on it I might be able to get it to run? It's stuck open in the first positon where it kinda resembles a fish fin. LOL
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4
Eds97ZJ is offline
