need someone with experience for advice - JeepForum.com
post #1 of 12 Old 01-14-2012, 09:05 PM Thread Starter
zach8935
1995 XJ Cherokee
so I bought a Jeep that was only half running when I got it and I've fixed most of the problems but I have some general questions. it's a 93 grand Cherokee Laredo 4x4. I don't have a console yet and no matter were I put the lever for the 4 wheel I cant get it to engage into full time and I wonder which would give me better mileage 2 wheel or full time. I also am wondering about the fact that I am getting like 10 maybe 12 mpg and I'm driving like an old lady and I've run injector cleaners, sea foam carbon cleaners, and Lucas stop slip transmission and I'm told I should be getting 18-22mpg. so I have no clue what it could be. so if anyone knows a way to improve it please let me know. it will be much appreciated. i would also like to know what a decent size and type of tires would be good if i'm just driving it as a car and for light camping other words i want it to ride good and not get stuck in GA red clay
zach8935 is offline
post #2 of 12 Old 01-14-2012, 09:12 PM
Bustedback
You need it fully running in order to get better mileage, 2wd will get you the best mileage, never use 4wd on dry pavement.
Bustedback is offline
post #3 of 12 Old 01-14-2012, 09:27 PM
KoreaZJ
1994 ZJ
Typical
10-12 city
18-22 non-city
KoreaZJ is offline
post #4 of 12 Old 01-14-2012, 09:34 PM
WhiteOut
WhiteOut's Avatar
2wd makes no difference on MPG, the front end is still spinning. You cant use 4PT on the pavement when its dry, so just use 2wd.
Best bet would be to make sure your tires are correctly inflated (do the chalk test) and do a tune up. Good plugs and wires, new air filter, clean the IAC.
WhiteOut is offline
post #5 of 12 Old 01-14-2012, 09:35 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Believe your case positions are 2wd, full time, part time, n, 4lo. Is it an 8 or a 6 cylinder? Duratrack, bfg at, both great highway medium off-road, but can be a problem in sticky mud. Bfg long trail is great highway, light off road, poo in mud.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #6 of 12 Old 01-14-2012, 09:51 PM
ZeeJay1997
if you havent changed the plugs and you plan on doing so, use the plugs that are on you emiisions sticker under the hood. Should be a champion copper plug. Be sure it has an OEM O2 sensor, not a Bosch.
Is the check engine light on?
ZeeJay1997 is offline
post #7 of 12 Old 01-15-2012, 12:04 AM
Mickey_D
Another thing to check would be to do an intake leak check around the plenum. That is if it's a 5.2L
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #8 of 12 Old 01-15-2012, 12:32 AM
PolkaPower
It's a 4.0 so no plenum. Don't put any Lucas or other junk in your tranny. It doesn't meet the requirements that your trans fluid does and should be used as a last ditch effort if you need a rebuild. Other than that you are just diluting your transmission fluid. Make sure your battery cables are clean and change your plugs, wires, cap and rotor, 02 sensors, oil, air filter, and make sure your catalytic converter is in good shape. If you just got it, I would change all of the fluids in it to the last drop and replace with brand new. There is a good chance that your t case shifter linkage needs to be adjusted which isn't hard to do just do a search. Also 2wd doesn't give you any better mileage, the front still turns no matter what.
As for tires, I like this company a lot. www.treadwright.com
PolkaPower is offline
post #9 of 12 Old 01-15-2012, 04:05 AM
torchd
2003 WJ
Like many people have already stated... Do a complete tune up. new spark plugs, new wires, new cap and rotor, new ignition coil and ignition wire. Change your air filter, properly inflate all your tires. Clean your throttle body, clean your IAC. Hell even change the oil in your transfer case and front/rear diffs. While you're at it, replace your O2s as well
Good Luck
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #10 of 12 Old 01-15-2012, 05:32 AM
sevenscrew
how much could a upstream bosch o2 in 5.2 affect gas mileage?
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #11 of 12 Old 01-15-2012, 07:45 AM
ZeeJay1997
It may not affect it at all. It could affect mileage since it is the main sensor in the fuel/air ratio calculations. It's just a good idea to change it if you dont know the history of the vehicle.
post #12 of 12 Old 01-15-2012, 09:51 AM
PolkaPower
Just use OEM parts then you don't have to worry.
grand cherokee , mpg , wheels
JBA UCA experience 05WKinPA WK Grand Cherokee & XK Commander Forum 16 05-02-2011 12:41 PM
BFG MT experience tirus89 ZJ Grand Cherokee Forum 22 09-04-2008 01:32 PM
Anyone experience this??? XKJeep06 WK Grand Cherokee & XK Commander Forum 2 01-16-2008 02:48 PM
GC Experience thus far 07JGC WK Grand Cherokee & XK Commander Forum 2 10-05-2007 12:11 PM
first experience with DW mdsuave13 ZJ Grand Cherokee Forum 17 12-06-2006 03:15 PM
