Need some quick advice - JeepForum.com
post #1 of 13 Old 05-07-2013, 02:40 PM Thread Starter
Robinfortmill
My jeep, 1998 zj 4.0 select trac, all of a sudden lost power on my way home. Had to be towed home. now it won't start at all. not sure where to start. there was a burning smell when it first started happening. also the coolant sensor bad light has been coming on occasionally. any help would be great....thanks
1996 ZJ, 4.0L, 3.73 Gears, Select-Trac, Flowmaster Exhaust, Mopar Roof Rack Basket, E3 plugs
Robinfortmill is offline
post #2 of 13 Old 05-07-2013, 02:52 PM
JeepNicholson
What kind of burning smell, meaning like burning oil, gas, plastic, coolant? I'm guessing you've checked to see if it has coolant in it?
Is it turning over at all, or just no spark? Any electrics working at all? Is there pressure at the fuel rail?
JeepNicholson is offline
post #3 of 13 Old 05-07-2013, 02:56 PM Thread Starter
Robinfortmill
burning oil i think it will turn over but no spark.....i just pulled the air intake off and smoke was coming out of the intake manifold
post #4 of 13 Old 05-07-2013, 02:58 PM Thread Starter
Robinfortmill
electronics all seem fine......coolant is fine......temp never increased while i was driving
post #5 of 13 Old 05-07-2013, 03:22 PM
JeepNicholson
Is there any oil on your air filter? My thinking is that maybe your ccv elbows or tubes could be clogged, blowing oil into your air intake, or possibly blowing oil from under the valve cover onto your exhaust manifold which would explain the burning smell.
One tip I've got if you pull out your ccv elbows is to let them get warm first even if it just means parking in the sun for a while if you can't start it, if they're cold they'll just break off.
While you're there you can try checking your IAC which I imagine might be all gooey if there was a bunch of oil going into your throttle body.
Both are pretty cheap and easy things to check, hopefully it works
post #6 of 13 Old 05-07-2013, 04:27 PM Thread Starter
Robinfortmill
no oil in the filter and the ccv's are not clogged.......its getting spark.....doesn't seem to be any oil in the throttle body....any other ideas?
post #7 of 13 Old 05-07-2013, 04:52 PM
AaronButler
the coolant sensor issue is nothing to worry about, Im sure most of us ZJ owners have that stupid wiring issue show up. Its a PITA to fix, so most people (myself included) just ignore it, lol.
I know you said the electronics are fine, but I still have to ask, have you checked your alternator and/or battery? Just because things like your radio turn on doesnt necessarily mean that all is well.
what did the burning smell smell like? Were you experiencing any rough engine symptoms before it died? I had an issue where my Jeep would ONLY die when it rained. It would start right back up when it was dry, but the humidity was causing issues with my computer, and it had to be replaced.
AaronButler is offline
post #8 of 13 Old 05-07-2013, 05:00 PM Thread Starter
Robinfortmill
Like burning rubber...and it has always drove rough.
post #9 of 13 Old 05-07-2013, 05:01 PM Thread Starter
Robinfortmill
Battery was dead when I got it back from the tow truck....but even when jumping it it won't start
post #10 of 13 Old 05-07-2013, 05:10 PM
Afdude88
Burning rubber could be because a failed alternator wasnt turning properly with the belt. I would check all the wiring to-from the battery and alternator and starter. You could always remove the alternator and have it tested at a parts store
When trying to jump start swap the starter relay with something else and make sure its good.
Obviously check all fuses for anything broken.
Is the cel coming on when turning the key to on?
Is the engine actually turning over? Or just nothing when you turn the key?
If its turning over but not starting, but has spark, check fuel pressure.
Even with spark check the coil with a multimeter. Maybe the spark isnt strong enough for ignition.
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #11 of 13 Old 05-07-2013, 05:15 PM
tucsonzj
i'm goin with alternator is shot. Check your belts for any unusual or extreme wear, can show damage and hint in the right direction.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #12 of 13 Old 05-07-2013, 05:36 PM Thread Starter
Robinfortmill
I will check that out thanks
post #13 of 13 Old 05-08-2013, 08:26 AM Thread Starter
Robinfortmill
quick recap
driving home the gas pedal got hard to push...lost power.....got towed home and then it wouldn't start.
Still turns over and has spark.
Seems to be getting fuel.
Belt looks fine.
plugs look clean.
not sure what to look at next.
