Need some help - JeepForum.com
post #1 of 7 Old 09-17-2013, 06:32 PM Thread Starter
86redryder
Need some help
I have a 97 Grand Cherokee with a 4.0 automatic for about 2yrs. It has always cranked over for about 30secs before it would start. Yesterday I was driving it and it shut off completely.The fuel pump is kicking in and its getting fuel. The fuel gauge doesnt show any fuel even though it has half a tank. The voltmeter gauge doesnt work neither does the oil pressure gauge. It just cranks over and wont start. Tried hooking up an engine diagnostic tool and it says no link. Think maybe the computer is shot. Any help is apperciated.
86redryder is offline
post #2 of 7 Old 09-17-2013, 07:08 PM
newfieZJ
In those 2 years , what maintenance was done .
Check fuse 7 for the gauges 20amp , 2nd row , farthest in
newfieZJ is offline
post #3 of 7 Old 09-18-2013, 12:00 AM
Oldfrog
2007 WK
That year had a recall on the fuel tank sending unit. Take your VIN# to a dealer and check to see if it was done or look it up online. I think Chrysler has a site for checking your recalls.
Do that before you tackle the stalling problem....it might be connected. If not, check our Zeejay's "12 things to check if your Jeep is stalling", here in this section. It's about time your PCM went bad anyway. Most of the rest already have. I'm on my 5th one.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #4 of 7 Old 09-18-2013, 04:31 AM
ZeeJay1997
Mine was getting to where it had long starts. I cleaned the battery terminals and everything is peachy now.
ZeeJay1997 is offline
post #5 of 7 Old 09-18-2013, 10:40 AM
dusterdude
Crank sensor?
dusterdude is offline
post #6 of 7 Old 09-18-2013, 05:13 PM Thread Starter
86redryder
Thanks for all the help. It ended up being the computer. Have one coming tomorrow froma junk yard. Should be good to go then.
post #7 of 7 Old 09-18-2013, 05:39 PM
newfieZJ
Thought as much but try to avoid jumping right out there and say spend a couple hun without knowing a few more things first . Good Luck , and keep us posted to how it turns out for you .
How was it diagnosed ?
newfieZJ is offline
