Need to replace one of my tweeters! - JeepForum.com
post #1 of 23 Old 06-17-2009, 01:14 PM Thread Starter
DjDiddles
2017 KL Cherokee
So about 2-3 weeks after buying my WJ I have already blown out my passenger side tweeter!! Now it sounds terrible if I turn my stereo up! Is it hard to replace them? I just want to pick up a cheap pair and replace them both but not sure how to do it! Thanks!!
2017 KL Trailhawk
Colorado Jeep Club #977
DjDiddles is offline
post #2 of 23 Old 06-17-2009, 01:30 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Just buy some new ones, rewire and mount them somewhere else. It is next to impossible to find ones that fit in the original mounts and a b**** to get to them.
~James
ezflip is offline
post #3 of 23 Old 06-17-2009, 01:43 PM
acmf74
I bought some infinity's and they fit well and sound ok.
acmf74 is offline
post #4 of 23 Old 06-17-2009, 04:31 PM Thread Starter
DjDiddles
2017 KL Cherokee
Did you have to pull that whole dash panel off? I'm not big on wiring and the electronics but hopefully I can have a friend help!
2017 KL Trailhawk
post #5 of 23 Old 06-17-2009, 04:42 PM
JG_Canuck
To gain access use a plastic spatula or something similar and simply pry up on the edge of the panel covering the tweeters.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #6 of 23 Old 06-17-2009, 05:12 PM
gmp211
A little trick; fade your stereo to the back until the buzzing of the tweeter goes away. I have mine 90% to the rear and I don't hear the tweeter at all.
Check this site out.
http://www.wjjeeps.com/audio.htm
2002 WJ - Forest Green
gmp211 is offline
post #7 of 23 Old 06-18-2009, 06:56 AM
Double E
Double E's Avatar
The tweets are a cinch to replace, as said just pop off the trim part and there you go. I picked up a set of Pioneer replacements from Radioshack several years ago and they dropped right in after I tweaked the outer plastic housing of the speaker a bit.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 23 Old 06-18-2009, 08:17 AM
JacksonsHole
I'm no good at wiring either and have been replacing all my speakers in my WJ....
The dash speakers are far and away the easiest. The vent piece of the dash pops right out and the speakers are easily accessible.
This started a fight last time I said this (about a year ago....still no issues haters!!!), but I bought cheap Blaupunkt full range 3.5" off of eBay and installed them with ZERO modifications.
My one complaint.....they are TOO loud. They overwhelm us in the front, so I fade mostly to the rear and it sounds great.
Good luck! Piece of cake install....and a great way to start tinkering with the WJ.
JacksonsHole is offline
post #9 of 23 Old 06-18-2009, 10:26 AM
YJDuff
If you don't want to spend the money on replacing it. You could just use some black silicone and seal the crack in the tweeter let it dry for a day and put it back in. HTH
"Life is a garden, dig it!"
02' 4.0 WJ
2" bb lift
245/75/16 Goodyear MT/R
Rusty's Tow Hooks
YJDuff is offline
post #10 of 23 Old 06-18-2009, 10:39 AM
JG_Canuck
x2. I used some speaker service cement to improve the crappy stock surrounds. Did this 2 years ago, and had been fine ever since. And yes, I do occasionally crank it waaaay up.
post #11 of 23 Old 06-18-2009, 10:47 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Hmmm, didn't know that whole dash piece pops out like that. There I was trying to figure out a way to get to them from underneath. Thats why I just said the hell with those and got three way 6x9's in the door. They sound just as good IMO.
~James
ezflip is offline
post #12 of 23 Old 06-18-2009, 10:49 AM
pointech
2014 JK Wrangler
I bought some off eBay...many to choose from (including factory replacements) and most include instructions.
pointech - Tom in Virginia
2014 Wrangler Sport
SOLD 1994 Wrangler YJ S - 4 cylinder 5 speed -
SOLD 1997 Jeep Wrangler TJ SE
pointech is offline
post #13 of 23 Old 06-18-2009, 11:39 AM Thread Starter
DjDiddles
2017 KL Cherokee
Nice! Thanks for all the advice! Doens't sound as hard as I thought!! Hopefully I can get to them soon!
2017 KL Trailhawk
post #14 of 23 Old 06-18-2009, 02:03 PM
00Limited
Very easy, I would say the hardest part is getting the screws out. I had to use a flexible hose screwdriver(snake) as I call it and they came right out. Very easy switch out. Make sure to be sure that the cover goes back on all the way, I have a slight rattle now from not making sure I secured it back good enough and when it pisses me off enough one day, I'll fix it. I bought some factory replacements on ebay for like $30 shipped.
Kevin Moore
00 WJ Limited
00Limited is offline
post #15 of 23 Old 06-19-2009, 03:00 AM
JMOSS
As i wrote some time ago:
You can fix it by yourself, I did 1 and half year ago and they work perfectly.
The problem is to explain it, i'm italian.
I try:
Obvisuoly you have to disconnect them
then you have to buy Vinavil
I dont know if you have it in your country but its just the standard white liquid wood working glue, used also for paper....
Vinavil - Vinyl and acrylic emulsions for paints, adhesives, paper.
Buy someting similar if you dont find it in US.
Then you need toilet paper, yes, not joking....
Put paper on tweeter membrane and put some glue all over, attacking also the edges of the tweeter.
wait one day....
That's it.
$ ???? 1 box?
this tips come from technical musical instruments expert....
99 WJ 4.7V8 Limited QTII , LPG system, 180 Tstat, Magnaflow cat, Up country coil springs, Procomp MX6 shocks absorber, ADDCO swaybars & gresonable bushings, General Grabber AT2 tires, Usa spec pa-chr11 Ipod interface.
JMOSS is offline
WJ Tweeters.....again Firegod14 WJ Grand Cherokee Forum 16 07-13-2010 06:04 AM
what do you guys replace your infinity tweeters with? 2k2wranglerx ZJ Grand Cherokee Forum 6 01-23-2009 08:02 AM
Where to buy Tweeters? madmarchhare ZJ Grand Cherokee Forum 4 08-27-2006 06:45 PM
WJ tweeters... SteelBlue_WJ ZJ Grand Cherokee Forum 16 04-19-2006 02:08 PM
tweeters Arkansas_WJ ZJ Grand Cherokee Forum 4 11-19-2005 11:59 AM
