Need Quick Help, Power Window Won't Roll Back Up....... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Need Quick Help, Power Window Won't Roll Back Up.......
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-28-2008, 07:09 PM   #1
Rocket254
Title says it all. It's a 2000 Jeep Limited. I was rolling the window up and at the top it made a loud pop and just started slowly falling down. Now it won't roll back up. What's wrong and is there a quick fix?
Thanks in advance....
Rocket254 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 07:17 PM   #2
Windowsrookie
Nope, not a quick fix. Search, you have to replace the regulator. Or you may be able to replace just the plastic piece.
http://pocketlogger.com/?pid=jpw
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 07:17 PM   #3
southernx
Window regulators? Maybe offtrack? I don't know much about Jeeps yet but in the past regulators create this problem when they decide to fail.
southernx is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 09:22 PM   #4
ct-snoman
2003 WJ
purchase the metal piece linked to in Windowsrookie post (might as well purchase 4 of them since if one regulator fails, the rest probably arent too far behind).
Replacing the window regulator is not that bad of a job, just time consuming the first time around.
Figure you'll probably spend about 1-2 hours doing it.
http://www.jeepin.com/features/wj_window_regulator/
ct-snoman is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 12:25 AM   #5
MamapreneurSher
2003 WJ
I just signed up tonight so that I can contribute to this great place. I bought my Jeep earlier this year and 3 months later the right front window fell down and wouldn't go up. I paid a mechanic $325 to replace the mechanism.
Four months later, the left rear window does the same thing (Windowsrookie...you were spot on). This time, I did the research on my own before taking it to my mechanic. So now...I'll share this thread with him so he can repair it by following the link below. Thanks ct-snoman for that link.
MamapreneurSher is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 05:40 AM   #6
coralman
its the beam Jim
coralman's Avatar
There was a you tube video I think that showed repair.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is online now   Reply With Quote Quick reply to this message
