Need to pump brakes in order to get pressure - Page 2 - JeepForum.com
post #16 of 43 Old 02-03-2010, 09:20 AM
JrMechanic
Originally Posted by vdub View Post
Not from what i have heard. There was a poster on here a while back on here that had a soft brake pedal that would go all the way to the floor. He also had the same symptoms of a vacuum leak and found the leaks and fixed them. this also fixed his soft brake pedal.
If the MC was bad the pedal would not gain pressure by pumping it. it would keep going to the floor regardless of if you pump it or not.
Go pump your brake pedal with the engine off, then tell me a vacuum leak is going to give you a soft pedal
Sure, a total MC failure will yield no brake pressure. However seals get old and leak without totally failing.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #17 of 43 Old 02-03-2010, 09:43 AM
vdub
1994 ZJ
what do you mean. when i pump my brakes with the car off they are stiff.. when i start to jeep up is when it gets soft.
i found this old thread about bleeding the abs pump and maybe having flow-by in the pump itself...
http://www.jeepforum.com/forum/f13/m...htmare-526360/
vdub is offline
post #18 of 43 Old 02-03-2010, 09:58 AM
JrMechanic
Thank you for further supporting my point while not even knowing what you're talking about
post #19 of 43 Old 02-03-2010, 10:23 AM
vdub
1994 ZJ
your welcome my good sir.. my and brake systems are like obama and a good president... they just dont mix.
vdub is offline
post #20 of 43 Old 02-03-2010, 10:32 AM Thread Starter
97DCZJ
Could be a vacuum leak.
Does your heat go to defrost when your accelerating or putting load on your jeep? Also does your cruise conrol work?
Yes. I always keep forgetting to make a post about the heat going to defrost when I accelerate hard. The cruise control DOES work too.
as for pumping the brake while the engine is off, the pedal gets more stiff. but once I start the jeep up, the pedal drops to the ground, and I have to pump a few times for pressure to build up, but still feels soft, not stiff where it should be.
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #21 of 43 Old 02-03-2010, 10:43 AM
vdub
1994 ZJ
when was the last time you replaced your brake lines.. i was just reading another thread saying the oem rubber brake lines can stretch and cause a soft brake pedal
vdub is offline
post #22 of 43 Old 02-03-2010, 10:48 AM Thread Starter
97DCZJ
which brake lines?
well...either way, i never replaced any. lol
they could cause a soft brake pedal, but what's the reason for everytime i first press the brake, it goes to the floor with the Brakes light coming on, and then after I pump the brake a few times, it builds up pressure?
I know the Brake light is letting me know I have a pressure leak somewhere, and if I had a soft brake pedal from the rubber brake lines stretching, I shouldnt be able to press the brake all the way down
; V8 4.7L, Stock.
97DCZJ is offline
post #23 of 43 Old 02-03-2010, 10:53 AM
vdub
1994 ZJ
yeha. idk. i was just searching threads... i have the exact same problem with my brakes that you have with yours... right down to the brake light
vdub is offline
post #24 of 43 Old 02-03-2010, 01:11 PM Thread Starter
97DCZJ
Okay well I just bled them, n fixed my problem. Mustve been air in the lines because they're stiff and the pedal moves I would say an inch or two
; V8 4.7L, Stock.
97DCZJ is offline
post #25 of 43 Old 02-03-2010, 04:46 PM
JrMechanic
The problem will come back. As I said, air doesn't just magically appear in the lines, it has to be introduced from somewhere. Being that bleeding your brakes fixed the problem, I'd say the master cylinder has a slight leak allowing air to be introduced into the system. That explains why it's fixed now.
post #26 of 43 Old 02-03-2010, 08:07 PM Thread Starter
97DCZJ
Well I also just replaced my driver side caliper and only bled that caliper. none of the others
prob shouldve mentioned this in the beginning, shouldnt i have lol
; V8 4.7L, Stock.
97DCZJ is offline
post #27 of 43 Old 02-03-2010, 08:15 PM
JrMechanic
Yeah, probably That pretty much changes everything.
post #28 of 43 Old 02-03-2010, 08:30 PM Thread Starter
97DCZJ
haha. it was happening before I replaced that caliper tho too. but I replaced the caliper because I know it's been bad for awile
; V8 4.7L, Stock.
97DCZJ is offline
post #29 of 43 Old 02-03-2010, 11:41 PM
vdub
1994 ZJ
How can you tell if a caliper is bad.. After jr's insight I think mine could be a bad MC. How can I test the MC. If the brake booster fails doesn't the pedal get really stiff??
I need to fix this asap its really starting to piss me off..
vdub is offline
post #30 of 43 Old 02-04-2010, 05:03 AM Thread Starter
97DCZJ
I can tell the caliper was bad because it was kinda seized up a little. It was hard to spin the wheel when it was in the air. n only that tire, no others
; V8 4.7L, Stock.
97DCZJ is offline
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
brakes on 2000 wj - how to relieve pressure from ABS takedown ZJ Grand Cherokee Forum 3 06-25-2009 02:54 PM
95 4.0 fuel pump pressure? my2monkeys ZJ Grand Cherokee Forum 2 03-11-2008 08:20 AM
Oil pump or pressure sensor? Yardman Harry ZJ Grand Cherokee Forum 3 10-22-2007 10:24 PM
Fuel pressure and pump rkreger2 ZJ Grand Cherokee Forum 9 08-17-2006 11:20 PM
