Need a little help with a fuse - JeepForum.com
post #1 of 8 Old 07-23-2011, 10:59 PM Thread Starter
vonericsen
I keep blowing fuse 12 whenever I turn my parking lights on.
I've removed all the bulbs and I've been checking all the wiring for exposed wire, but I haven't found anything.
I've also now tried 2 other switches with no success.
This happened once before to my dad when he towed a trailer but that was years ago, this time there is no trailer involved.
The most recent thing I've done is replaced the alternator, but I dont see how it could be that because the fuse blows whether the engine is running or not, so I haven't disconnected it yet. (trying that in the morning).
Anyone have other things I should try or look for? Think it could be the trailer harness?
Thanks
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #2 of 8 Old 07-24-2011, 12:08 AM
CrazyMacaw
Trailer lights come on with parking lights as well as turn signal/brake.
I would definitely check the plug & harness.
CrazyMacaw is offline
post #3 of 8 Old 07-24-2011, 12:23 AM
airwolf9090
I would check it too! For a while my reverse lights was sending SOS signals while driving down the road and sometimes even stay on while parked and shut off. Turned out someone cut the 7point connector and spliced in a pig tail and one of the wires was shorting out on another wire. Only reason i figured it out was when i was walking behind my jeep and the lights were on i kicked the pigtail and the lights went out.
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #4 of 8 Old 07-24-2011, 09:39 PM Thread Starter
vonericsen
I disconnected the alternator and the trailer harness and still no luck
I also have yet to find any exposed wire
post #5 of 8 Old 07-24-2011, 10:01 PM
airwolf9090
Okay this may sound weird but do you have an aftermarket radio?? in an old Trans-Am i had some reason it kept blowing the fuse for the headlight motors and taillights..... Turns out the radio was not grounded right and everytime i switched on the headlights it would blow the fuse and one day i was messing with the radio and had its ground unhooked and i bumped the headlight switch and it didn't pop the fuse. so i hooked the ground back up and it blew the fuse so i changed the ground to a different spot and never had the problem again.
1996 Jeep ZJ Orvis
post #6 of 8 Old 07-24-2011, 10:18 PM Thread Starter
vonericsen
I do have an after market radio and I just tried that with no luck...still blowing fuses
post #7 of 8 Old 07-24-2011, 11:44 PM Thread Starter
vonericsen
I have a few more things to try tomorrow, but I did find an aftermarket alarm in my jeep. If anyone knows anything about it please let me know. Its a sky-trak 200m.
I don't know if that would cause these problems or not but I can't find any info on it.
post #8 of 8 Old 07-25-2011, 06:19 PM Thread Starter
vonericsen
I took it to a shop that specializes in electrical problems and they almost found the exact location before it disappeared...it is somewhere in the rear quarter panel that holds the trailer wiring.hope it stats hidden...
