Need help with ZJ crossmember ASAP - JeepForum.com
post #1 of 4 Old 08-16-2009, 11:09 AM Thread Starter
Steve01WJ
2005 WK
: I am in the finishing stages of the replacement of the rear trans seal on the zj. When putting the crossmember bolts back in one of the bolts became crossthreaded and is now stuck half way in. Can I drive it with just 3??? The other is still kinda in.
I was looking at nutserts on here....looks like I could drill out the hole and put one of those in. Any recommendations?
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #2 of 4 Old 08-16-2009, 11:22 AM Thread Starter
Steve01WJ
2005 WK
http://www.jeepforum.com/forum/f9/nutsert-transfer-case-removal-install-390635/
Would this work??
post #3 of 4 Old 08-16-2009, 02:02 PM Thread Starter
Steve01WJ
2005 WK
nothin? Im gunna try and tap it to a slightly larger size..
post #4 of 4 Old 08-16-2009, 07:00 PM Thread Starter
Steve01WJ
2005 WK
Well ok....so I drilled out a new hole next to the existing and tapped it for a larger grade 8 bolt. Seems to be fine. Just ground the broken one down a bit.
wj crossmember jeepy01 ZJ Grand Cherokee Forum 8 03-12-2009 08:36 PM
Crossmember BigItalianBeast ZJ Grand Cherokee Forum 1 01-11-2008 07:44 PM
Crossmember? C-DUB ZJ Grand Cherokee Forum 12 06-19-2007 10:42 PM
New Crossmember Reswob ZJ Grand Cherokee Forum 2 11-17-2005 03:41 PM
bent crossmember quicksilver97 ZJ Grand Cherokee Forum 5 07-30-2004 08:49 AM
