Need help w/conflicting parts from two manufacturers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Need help w/conflicting parts from two manufacturers
The Boss is away but Erin is here to STAY with a F.Y.S. SaThe Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-27-2015, 03:17 AM   #1
Trippysmurf
Ok so I have an issue with a track bar that came with my lift from Rough Country and the Knuckle to knuckle hybrid steering kit I got from Rusty's. Hoping to get a little advice here. The steering stabilizer seems to be the issue. According to how it reads I should be installing it with the bolt upwards to the steering. However, when I do this I run into the issue where the stabilizer will hit the rough country track bar since the main part of the stab. is down towards the ground (bolt upwards). Is there something I am missing? I have tried to rearrange the stabilizer a few ways and the only way it fits it will also rub against the bottom of the oil pan so that is a nogo.
Trippysmurf is offline   Reply With Quote Quick reply to this message
Unread 05-01-2015, 07:13 PM   #2
Trippysmurf
Any ideas?
Unread 05-02-2015, 03:48 AM   #3
PolkaPower
Two crappy companies. Good luck.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 05:13 PM   #4
Trippysmurf
Anyone got any other advice that could possible be useful? I am debating getting diff knuckles to compensate and sort of "push" out the knuckle to knuckle bar in order to give the stabalizer room. If someone here has run into this same issue it would be helpful. Thanks again folks.
Unread 05-17-2015, 05:24 PM   #5
Cbob4
First...have you talked to the tech guys at both companies? What have they told you? That their stuff is supposed to fit? You need to call both companies and tell them your problem.
Second...this is your steering system, the second most important system on your vehicle. Don't try to re-engineer it to get stuff to "fit". If the stuff doesn't work, demand to know why, find out if you are doing something wrong...or send it back and get a refund. Period.
And THAT...is useful information...
Cbob4 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 05:36 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
Which steering kit are you using? Got pics?
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is online now   Reply With Quote Quick reply to this message
