Need Help with sound system - JeepForum.com
post #1 of 12 Old 07-29-2009, 11:31 AM Thread Starter
Coledawg
2003 WJ
Ive got a 2003 Overland with the infinity sound system I am going to be replacing the head unit with an Eclipse 3200 and using my memphis components for the front speakers and throwing in some Rock ford speakers for the rear. these memphis components ar 6.5" so bass is not so much haha so im thinking about throwing some 6X9s that have decent bass like the stock ones and putting the Rock fords in the rear. If i put speakers in the rear i assume they will use the factory amp whre as the front ones will be running off amp?
Coledawg is offline
post #2 of 12 Old 07-29-2009, 11:40 AM
AEagle326
if you put in a new headunit you wont be able to wire up the amp as far as i'm aware
Andrew
1995 Grand Cherokee Orvis Edition
You can never go wrong with an Orvis.
AEagle326 is offline
post #3 of 12 Old 07-29-2009, 12:19 PM
ABerry
true and don't go 6x9 your options will be expensive and limited, go with 6.5" there are adapters, thats what I did for my fronts
IRO 3", BFG MT KM2 31's, MX-6's
University of Oregon ALUMNI GO DUCKS!
ABerry is offline
post #4 of 12 Old 07-29-2009, 01:48 PM
01Limited45324
I replaced my headunit and it's wired up to the amp fine. I have Kicker 6x9s in the front doors that kick *** and sound great. Weren't too expensive either.
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #5 of 12 Old 07-29-2009, 02:08 PM Thread Starter
Coledawg
2003 WJ
So i guess ill just use my 6.5" components in the front and i guess throw some 6.5"s in the back i just gonna have no bass haha until i get money to replace a sub lol o well
Coledawg is offline
post #6 of 12 Old 07-29-2009, 02:34 PM
K10roc
agreed i put in a flip screen and wired up the amp just fine.. granted i then wired in 3 more, and eventually replaced the stock.. but yes it will work jus fine
Joe K.
"if you can buy it, you can build it BETTER"!
2000 Jeep grand WJ limited, 245/75/16, Thrust 2 chamber muffler, 2in bb, rough country shocks, slotted and drilled rotors, Torqflo trans cooler, powder coated calipers, custom made CAI, K&N cone filter, ported and polished throttle body, Chip, Torqflo trans cooler, 6000k HID, PIAA fog, lots of powder coating and blacked out parts
K10roc is offline
post #7 of 12 Old 07-29-2009, 03:27 PM
ABerry
I don't really see why you would want to use your stock 180w amp, but I guess if you have to save money then by all means.. also 01limited45324 is right, I guess they aren't too expensive, but your options are definitely limited, and mounting depts for aftermarket 6x9 are extremely close if not deeper than possible in our WJ's
I have a pioneer premier P600UB deck, 2 infinity kappa 6.5 components in the front, 2 6.5 infinity kappas in the rear powered with a alpine pdx 4.100, and a JL W7 with JL 1000/1 amp for the bass.. nice is an understatement
ABerry is offline
post #8 of 12 Old 07-29-2009, 04:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you purchase good 6.5's they'll have excellent bass response. mine are pretty decent.
ratmonkey is offline
post #9 of 12 Old 07-29-2009, 04:32 PM
01Limited45324
My Kickers have plenty of bass and fit into the housing just fine. Both speakers cost, I think, $80. It's worth it.
FYI, if you replace your head unit your steering wheel controls won't work with the radio unless you buy an adapter. I wish someone had told me that before I bought mine... :
-Tom
2002 BMW 530i
post #10 of 12 Old 07-29-2009, 04:54 PM
ABerry
I have the adapter to retain steering wheel controls
ABerry is offline
post #11 of 12 Old 07-29-2009, 08:28 PM
01Limited45324
I need to buy one, but I need a job first... Where did you get yours from? Most the ones I've seen are between $50-$75. Did you install it yourself?
-Tom
2002 BMW 530i
post #12 of 12 Old 07-30-2009, 05:34 PM
ABerry
I got it from a local shop here for a very overpriced amount, I think it was like $100 but they installed it free. I looked at the thing and I immediately knew I was not going to be doing it myself, works pretty well about 90% of the time but 10% it messes up thinking i press a different button than I did, I dont know how the system works, I think it is some sort of remote, because for example pressing the center button on the left sets my deck to ATTN mode (75% less volume) and pressing the right center button changes the source, then left rocker is for track selection and right rocker is for volume but sometimes when I press any button, the ATTN or volume it will do another random operation (I press ATTN and it changes the source) but only 10% of the time... it does it enough to where I still use the deck for control most of the time, the ATTN is extremely nice though since I'm always listening to music loud and it is an instant mute sort of
ABerry is offline
Sound System Upgrades lightning95sc WK Grand Cherokee & XK Commander Forum 30 07-20-2007 09:34 AM
Need help with sound system keeth1123 ZJ Grand Cherokee Forum 30 02-07-2007 07:07 AM
Sound System RAZZMANIAC ZJ Grand Cherokee Forum 3 06-22-2005 08:15 AM
Sound system? xinnocuous ZJ Grand Cherokee Forum 23 01-01-2005 09:39 PM
Sound System 2000GCLaredo WJ Grand Cherokee Forum 18 04-20-2004 09:28 PM
