Need help removing sway bar link - JeepForum.com
post #1 of 14 Old 04-27-2012, 05:46 PM Thread Starter
jwildman16
1998 WJ
I have a '98 GC. The front left sway bar link broke. The ball joint comes out of the socket. I got most of it off, but the ball and the threaded bolt connected to it are stuck in the end of the sway bar. Any suggestions on how to get it out? I got a Pitman arm puller, but it ended up being too big to grab the sway bar, so I can't push the bolt out with that. Any other ideas?
I swear it looks expanded in there. I guess after 15 years of being in there, it's gotten pretty comfortable...
jwildman16 is offline
post #2 of 14 Old 04-27-2012, 09:57 PM
jtackerman28
Tie Tod seperator
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #3 of 14 Old 04-27-2012, 10:06 PM
booked101
^ or a smaller pitman arm puller.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
post #4 of 14 Old 04-27-2012, 10:51 PM
Bigdjs123
Originally Posted by jtackerman28
Tie Tod seperator
And a big hammer
Bigdjs123 is offline
post #5 of 14 Old 04-29-2012, 11:41 PM
big_rudy101
hahaha.
Ahh man, I just had to do this like 2 weeks ago.
Its a son of a gun, I know..
How did I do it?
Torch. Worked liked a charm.
"Jeep is America's only real sports car" - Enzo Ferarri
big_rudy101 is offline
post #6 of 14 Old 04-29-2012, 11:42 PM
Freestyle713
1994 ZJ
Just cut it off. They sell them for $15 at auto zone.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #7 of 14 Old 04-30-2012, 12:20 AM
Mickey_D
What I did was fully removed the sway bar from the vehicle. It's only 6 bolts. Hardest part was getting it over the lower radiator hose.
Once out, set the sway bar on a curb and bash the remainder of the end link out. Works a treat and is SOOOO much easier than any other alternative. Only took two hits with a 16oz sledge to get both of mine out and they were 200,000 mile originals.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #8 of 14 Old 04-30-2012, 07:21 AM
gearheadnick
Mine did the same thing. I got a "pickle fork" attachment for my air chisel and gave it hell. It popped out reasonably quick.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #9 of 14 Old 04-30-2012, 08:12 AM Thread Starter
jwildman16
1998 WJ
Originally Posted by big_rudy101
hahaha.
How did I do it?
Ah, sweet. What did you do exactly, just heat it up a bit and then you were able to free it?
post #10 of 14 Old 04-30-2012, 08:16 AM Thread Starter
jwildman16
1998 WJ
I was hoping to not have to remove the whole sway bar, but I think you may be right - it might be the easiest way to go. You didn't have much trouble getting the bar out with the end links still attached?
post #11 of 14 Old 04-30-2012, 08:44 AM
Mickey_D
Not at all. It took some head scratching to figure out how to get it over the lower rad hose, but it was a LOT easier than trying to get any major tools into the fender well to remove the end link while in place.
________________
#4
Mickey_D is offline
post #12 of 14 Old 04-30-2012, 04:42 PM
dusterdude
Its not hard to remove,i did it when i did my links
dusterdude is offline
post #13 of 14 Old 04-30-2012, 04:43 PM
Oldfrog
2007 WK
Over the lower hose?
( I cant remember if it's over or under)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 14 Old 04-30-2012, 09:46 PM
big_rudy101
I took a large socket and fit it over the ball, then took a big c clamp on put it on the bottom of the socket and on top of the post part. With the threads..
Tighted that down reealllllll nice and tight. Then took a torch to it and stood back. Be careful though. Because when the heat finally makes it give, and that clamp is tightened down, when it finally pops, it POPS!
It scared the hell outta me. But, it worked.
bolt , stuck , sway , sway bar link
Sway Bar Link Kit Sagona ZJ Grand Cherokee Forum 9 08-23-2011 11:00 AM
Sway bar link? congerz83 ZJ Grand Cherokee Forum 5 08-02-2011 07:14 PM
Sway bar end link help!!!! Mxracer201 ZJ Grand Cherokee Forum 2 05-14-2011 02:27 PM
Tie rod / Center link hitting Sway bar link Dodgeram1989 ZJ Grand Cherokee Forum 2 05-04-2011 12:45 PM
sway bar link help mayor_bloom WK Grand Cherokee & XK Commander Forum 1 08-22-2010 10:17 PM
