need help quick - JeepForum.com
post #1 of 4 Old 12-09-2011, 12:34 PM Thread Starter
paulrevere1991
need help quick
Jeeps been sitting for a couple of months, so i switched out batterys to start it, all that happens now is the starter motor spins without turning the engine, did i burn out a relay or something, i need to move it today.
Thanks in advance
Paul
paulrevere1991 is offline
post #2 of 4 Old 12-09-2011, 01:02 PM
azgrandjeeper
I would look at the fuses under the hood. Check all the smaller ones first. There are a couple that could be blown and causing it not to spark
azgrandjeeper is offline
post #3 of 4 Old 12-09-2011, 01:21 PM
e30nate
whack the starter a few times with a big wrench or a hammer. whe pinion isnt going out to reach the ring gear. happens most common when something sits for a while.
e30nate is offline
post #4 of 4 Old 12-09-2011, 02:33 PM Thread Starter
paulrevere1991
Turns out I had the battery polarity reversed. The jeep did not short out, it just killed the battery. Replaced the battery and all is well. Thx for the suggetions
Need quick help please!! zander21510 ZJ Grand Cherokee Forum 0 06-24-2011 04:04 PM
Quick, quick dosconect question 96zj1987 ZJ Grand Cherokee Forum 1 03-10-2011 03:41 PM
Quick Quick Quick....Front DS U Joint Removal Darthteddy ZJ Grand Cherokee Forum 3 08-11-2008 12:25 AM
Quick Quick Question - Mopar CCC Darthteddy ZJ Grand Cherokee Forum 4 12-05-2007 11:40 AM
231J/247 TC conversion.. quick,quICK,QUICK! UUJ1 ZJ Grand Cherokee Forum 7 05-25-2007 08:20 PM
