Need Help,please - JeepForum.com
post #1 of 3 Old 05-23-2013, 10:01 AM Thread Starter
chich
Need Help,please
This morning I went out to start the jeep and it wouldn't start.Jumped it and it started.When I took off I noticed the VIC and battery time were blinking on and off.This continued 'til I reached my destination(dentist visit Went to go home and issue persisted.Once back at the house,started checking fuse etc.-all were good.
Opened door and heard clicking from relay under glove box.It is the extreme right hand side one,first row, facing glove box door.Swapped it out with another one and same issue.Was fooling around with some things and noticed when I had the fan on if I opened any door,fan would shut off,close door and it comes back on.Radio doesn't work and time is no longer flashing.As I said,all fuses are ok.Any help and suggestions would be most welcome.Thanks
chich is offline
post #2 of 3 Old 05-23-2013, 11:07 AM Thread Starter
chich
Well,my mistake.
After closer inspection,turns out a fuse WAS blown after all.Fuse #8 to be exact.Not sure WHY it blew,but after replacing all is good.That particular fuse controls quite a few things,but I'm still baffled as to why opening a door would cause the fan to shut off
chich is offline
post #3 of 3 Old 05-24-2013, 08:08 AM
KoreaZJ
1994 ZJ
Illuminated Entry Relay controls interior lighting, clicks when door is opened/closed.
KoreaZJ is offline
