07-06-2006, 01:45 PM
#1
Need help with O2 sensor wiring.
More trail carnage to fix:
When wheeling this past weekend, I ripped the exhaust apart on my GC. While the pipes went back together fairly easily, all the wires were ripped out of the body side of the O2 sensor plug. It seems like they came out clean with the metal ends intact, so all I have to do is stick the wires back in. But can someone tell me which wire goes where? My Chilton's book does not have the V8 diagram for this sensor (the one on the Cat).
The wire colors I have are:
O2 Sensor (still in the plug)
White
White
Black
Grey
Body Plug (with all the wires pulled out)
Black/Red
Black/Tan
Black/Blue
Green/Red
'96 Green ZJ Laredo V8; 4.5" SA lift, RE 4.5 Springs JKS CA's, MX-6 Shocks, OME SS, Kevins TB Conversion, JKS rear TB, JKS Discos, Kevins Sliders, 16x8 Pro Comp Wheels, Dunlop Mud Rovers (33's)
07-06-2006, 01:58 PM
#2
According to the Chrysler wiring diagram, the front has the same colors, so see if they are in real life and you can match them up.
BK/TN goes straight to ground
BK/LB goes to the PCM
BK/PK goes to the PCM
DG/OG goes to the PDC (underhood fuse box) to the asd relay.
Hope it helps, the diagram they give me tshows these wire colors at the sensor, too, but I know that the colors are different there like you say.
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
07-06-2006, 03:40 PM
#3
Does your diagram show which wire goes where in the plug? Maybe I didn't make myself clear. My O2 sensor is now installed in the cat and the 4 wires are connected to its plug. The body side plug is plugged into that, but has no wires coming out. The four wires that are supposed to go there are dangling loose and need to be shoved back into the plug. I just need to know which wire goes in which socket.
Thanks.
07-06-2006, 06:13 PM
#4
At this URL, http://reviews.ebay.com/UNIVERSAL-OX...:-1:LISTINGS:1, you will find that the two white wires are the heater leads, black is the signal lead and grey is the signal ground.
Referring to zjay's post: the DG/OR wire goes to one of the sensor white wires (it doesn't matter which), the BK/TN wire goes to the other sensor white wire, the BK/LB wire goes to the sensor grey wire, and then the remaining wire goes to the sensor black wire.
What you called Green/Red is very likely the wiring diagram DarkGreen/Orange (DG/OR), and your Black/Red would be the wiring diagram Black/Pink (BK/PK) or in the Haynes Manual it is Orange/Dark Blue (OR/DB). Colors appear different to different people, especially if the light is not the same.
HTH.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
07-06-2006, 06:23 PM
#5
Since the wires are ripped out … I think he is asking for the exact physical placement of the 4 wires in the connector?
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
07-06-2006, 06:44 PM
#6
The connector should have two parts, one part on the harness, which has had the wires ripped out and the other part attached to the O2 sensor pig tail. Since the two parts only go together one way, it should be easy to trace the pig tail wires to the pins on the pig tail connector and then across the connector to the pins on the mating harness connector. That would tell where to attach the harness wires.
07-06-2006, 07:08 PM
#7
That logic would be fine if the wires on each side of the connectors are the same color. My 1994 is not so fortunate. But this may help him if his is exactly like mine?
Orange with black stripe (engine side)…..white wire (O2 side)
Black with brown stripe (engine side)…..white wire (O2 side)
Black with orange stripe (engine side)…..black wire (O2 side)
Black with blue stripe (engine side)……..gray wire (O2 side)
Cheers Steve
07-06-2006, 07:24 PM
#8
I thought I had written this, but I don't see it:
According to the diagram I have, the wiring for the other O2 sensor has the same colors, etc. Possibly you could use it as a guide.
I just looked again, the wires are the same in the upstream connector, the connector even appears the same except for it's grey instead of black. You should be able to use it as an example.
a Pic--
You'll need to compare pic and veh to see which end they are looking at, I think.
DOWNSTREAM HEATED OXYGEN SENSOR CAV CIRCUIT FUNCTION
1 A142 18DG/OR AUTOMATIC SHUTDOWN RELAY OUTPUT
2 Z12 18BK/TN GROUND
3 K4 18BK/LB SENSOR GROUND
4 K141 18BK/PK DOWNSTREAM HEATED OWYGEN SENSOR SIGNAL
96 GC 4.0 175,000
07-06-2006, 08:19 PM
#9
Originally Posted by greasefingers
That logic would be fine if the wires on each side of the connectors are the same color. ...
I don't see why that logic requires the wires to be the same color on each side. Perhaps you could explain. Seems to me that is basically the same as what you used.
07-06-2006, 09:13 PM
#10
I have had too many beers to think about this anymore
Cheers Steve
07-06-2006, 09:49 PM
#11
Here's a hint: Read my first post and you will see the logic. Next read your first post. Then go to my second post which was my attempt to clear up what appeared to be your misunderstanding of my first. Your comment about same color wires only makes sense if you ignore what I said in my first post and aim your respond at the second. I will admit my mistakes when they are pointed out to me. Just don't point to something and say it is a mistake when it isn't.
