need help with motor problem? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > need help with motor problem?
Unread 07-21-2009, 08:47 PM   #1
spikeystrip
1993 XJ Cherokee
i have a 95 GC with the 5.2 and recently my motor started to run really rough. it would be fine when cold then when the choke opened up it would run rough. if i accelerate slowly my engine will buck and hesitate and usually backfire. but if i acclerate fast or floor it, it will run great just like it should. can anyone explain ot me what sensor it might be?- (TPS, ECU, MAP) suggestions? i havent had my codes read yet if there are any bc i have no check engine light. thanks
1993 cherokee country.
Rustys 5inch lift
firestone 31x10.5 w/ cragar d windows
1995 Grand Cherokee
Stock Daily Driver
AWD 5.2 V8
spikeystrip is offline   Reply With Quote Quick reply to this message
