Need help How to replace rear control arms - JeepForum.com
post #1 of 6 Old 07-22-2012, 08:38 AM Thread Starter
youlost2melol
I have a 1995 Jeep Grand Cherokee Limited, i had taken it get inspected and it failed for a quite a few reasons. One was the rear control arm bushings. From reading serveral posts on the forums i have found out its easier just to replace the whole control arm.
My problem is how to replace the controls arms. I have read that the lowers can be down without jacking up the Jeep but i havent seen much on how to do the upper control arms. I have seen posts about the front upper control arms but im sure changing the rear are different.
If anybody could just give me a guide to changing the rear upper and lower control arms i would appreicate it.
youlost2melol is offline
post #2 of 6 Old 07-22-2012, 03:51 PM Thread Starter
youlost2melol
anyone?
post #3 of 6 Old 07-22-2012, 04:38 PM
JasonStebbins
Probably the easiest thing to do besides changing brakes and oil. Put a 1/2 ratchet on one side with a 19mm socket and 19mm wrench on the other side. Remove the two bolts then install the new one.
The upper arms may be a Torx bolt rather then a standard Hex head. There are holes in the frame rail for a ratchet and extension.
No jacking required.
JasonStebbins is offline
post #4 of 6 Old 07-22-2012, 04:45 PM Thread Starter
youlost2melol
Thanks i thought so just wanted to make sure. Any tips to keep the alignment from getting to far out of wack?
post #5 of 6 Old 07-22-2012, 05:10 PM
Virmagicus
Virmagicus's Avatar
Remove and install one at a time. You may have a hard time getting the holes to line up so you might have to jack up one side a little or even use a ratchet strap to wrap the axle. There is no "aligning" the rear with stock arms.
Jeff
Virmagicus is offline
post #6 of 6 Old 07-22-2012, 05:13 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, one at a time.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
Upper and Lower Rear Control Arms.. Need To Replace Them torchd ZJ Grand Cherokee Forum 8 07-25-2013 01:11 PM
rear control arms coralman ZJ Grand Cherokee Forum 2 04-11-2012 05:43 AM
Rear ADJ Control Arms 94ZJ-318 ZJ Grand Cherokee Forum 7 10-19-2010 05:33 PM
rear control arms ejeep00 ZJ Grand Cherokee Forum 4 09-28-2009 03:07 AM
greasing my rear control arms, how should i go about it? 1337jeeper ZJ Grand Cherokee Forum 2 10-16-2005 11:00 AM
