Need Help in Finding Temp Sending unit - JeepForum.com
post #1 of 28 Old 07-06-2013, 07:12 PM Thread Starter
rosas214
1994 ZJ
Hello like the title says i need help in finding temp sending unit just bought this 94 Grand Cherokee y see a purple wire where the unit connects to but no luck in locating it not even the hole it goes in any help would be appreciated thanks
rosas214 is offline
post #2 of 28 Old 07-06-2013, 07:20 PM
riot1987
My (5.2) temp sending unit was on top of the motor kinda behind my water pump.
Build thread^^
riot1987 is offline
post #3 of 28 Old 07-07-2013, 08:54 AM
AVR2
Do you have a 4.0L or 5.2L? The sensors are in different locations on both. And on the 4.0L there are two sensors, one for the PCM and one for the dash gauge.
AVR2 is offline
post #4 of 28 Old 07-07-2013, 10:27 AM
sebian
The 93-95 V8 also has two sensors. One near the t-stat housing for the dash, the other behind the alternator for the PCM.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #5 of 28 Old 07-17-2013, 06:58 PM Thread Starter
rosas214
1994 ZJ
its a 4.0L im looking for the one for the dash gauge
rosas214 is offline
post #6 of 28 Old 07-17-2013, 08:17 PM
dellis
2005 WK
Or, if you prefer a picture, the engine coolant temperature sensor is this brass colored sensor with a black electrical connector, at the front of the engine:
dellis is offline
post #7 of 28 Old 07-17-2013, 10:28 PM Thread Starter
rosas214
1994 ZJ
dellis thank you but im looking for another one one that is supposed to be close to back of engine on the drivers side
rosas214 is offline
post #8 of 28 Old 07-18-2013, 12:11 AM
dellis
2005 WK
That is the temperature sensor that affects the temperature gauge on your dash. The other sensor, called the intake air temperature sensor, does not display anything on your dash. But, if that is what you want, here is it's location ... on the driver's side of the engine toward the firewall:
dellis is offline
post #9 of 28 Old 07-18-2013, 12:15 AM
dnuccio
you got those backward. the one behind the alternator is for the dash gauge, the one by the t stat housing is for the PCM
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 28 Old 07-18-2013, 02:57 AM
AVR2
Only on ZJs with the BCM; the BCM takes the coolant temp from the PCM and uses that to drive the dash gauge.
Pre-BCM models (93-95 I think) drive the gauge from a separate single-wire coolant temp sensor. On the 4.0L it's at the back of the cylinder head near the firewall, in the area of the #6 fuel injector.
AVR2 is offline
post #11 of 28 Old 07-18-2013, 08:45 AM
Jeeples
Jeeples's Avatar
^ x2
IIRC, the sensor the OP is looking for threads directly into the cylinder head. It shouldn't be too hard to find as I believe its the only electrical connector back there. Be careful when reinstalling the sensor, as its a fine thread that can strip easily.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #12 of 28 Old 07-18-2013, 09:29 AM
dellis
2005 WK
Thanks for the correction ... and I apologize to the OP for misinformation. My "pre-BCM" (1993) service manual doesn't list this temperature sending unit (or at least I can't find it), and the temperature sensor at the front of the engine has a main purple color to it ... but, in doing some searching I can see where there is indeed a sensor back there on some 4.0's (I can see it is on Cherokees, for example). Here's a drawing:
dellis is offline
post #13 of 28 Old 07-18-2013, 09:32 AM
sebian
Not to hi-jack the thread, but I broke the one behind the t-stat housing and my dash temp gauge reading was way off as a result. I did not get any codes for temps as I would have expected, if the sensor was sending an unexpected temp reading.
sebian is offline
post #14 of 28 Old 07-18-2013, 11:13 AM
dnuccio
maybe you have a really really late 95 with 96 electronics, because the sensor by the t stat housing shouldnt have anything to do with the gauge. 96+ only has 1 sensor. on 93-95, the sensor with 2 wires is for the PCM, the one with 1 wire is for the gauge.
R.I.P. Ratmonkey
dnuccio is offline
post #15 of 28 Old 07-18-2013, 12:44 PM
sebian
I have the 95 electronics, and the two sensors. One near my t-stat only has the one wire.
sebian is offline
