need help diagnosing my DW - JeepForum.com
post #1 of 8 Old 08-22-2007, 04:13 PM Thread Starter
Derek33
Derek33's Avatar
My DW occured after i first installed longer LCA's.
I thought it was a coincidence and was my left ball joint because i knew it was going bad.
the DW occurs only when my left front tire hits a decent sized bump. nothing occurs when both tires hit a big bump, or the right front tire hits a big bump, and not at any specific speed. only with the drivers front tire.
my ball joints are new, the CA bolts are tight,.
what could cause DW only on one side of the jeep?
Derek33 is offline
post #2 of 8 Old 08-22-2007, 04:25 PM
04WJfreedom
04WJfreedom's Avatar
I just started having the same problem but only when both my tires hit a good bump my wheel shakes hard from side to side for a few seconds.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #3 of 8 Old 08-22-2007, 04:30 PM Thread Starter
Derek33
Derek33's Avatar
some more info.
my left front wheel was sitting at an angle (like it would with a bad ball joint)
i put new ball joints in the left and right today, and the left tire still sits at an angle.
would it be a bad wheel bearing?
Derek33 is offline
post #4 of 8 Old 08-22-2007, 04:35 PM
Trailzj
Jack the left front wheel off the ground and check for play. Do you know if your toe is aligned?
2 1/2" lift on 33" Pro Comp Xterrains
I traded my ZJ for an AR15
Function before fashion
Trailzj is offline
post #5 of 8 Old 08-22-2007, 04:37 PM Thread Starter
Derek33
Derek33's Avatar
no play, my toe should be aligned decently.
Derek33 is offline
post #6 of 8 Old 08-22-2007, 06:10 PM Thread Starter
Derek33
Derek33's Avatar
i have a feeling that the reason my left wheel is angled outwords even after new ball joints may be the reason for the DW
Derek33 is offline
post #7 of 8 Old 08-22-2007, 07:35 PM
MotoX5874
check your tie rod ends on the driver side?. if your toe is off on the one tire that could cause dw, maybe think about getting your alignment checked out
Brian
// 5.2 // 4.5" iro // 33" baja claws
MotoX5874 is offline
post #8 of 8 Old 08-22-2007, 09:24 PM Thread Starter
Derek33
Derek33's Avatar
that would make sense, i havent gotten a legit alignment since i installed the rustys tie rod conversion. although ive had that installed and didnt have dw for a while untill i got the new arms
Derek33 is offline
Help diagnosing tranny. Jami ZJ Grand Cherokee Forum 5 09-08-2009 05:30 AM
Help diagnosing clicking DouginDenver ZJ Grand Cherokee Forum 1 01-24-2008 11:28 AM
TRE's and diagnosing. Derek33 ZJ Grand Cherokee Forum 15 11-24-2007 11:15 AM
help with diagnosing a squeek Derek33 ZJ Grand Cherokee Forum 7 07-25-2006 12:25 PM
ZJ won't start, need help diagnosing Trailzj ZJ Grand Cherokee Forum 13 10-01-2005 09:38 AM
