Need help battery dying. - JeepForum.com
post #1 of 17 Old 05-06-2013, 05:21 PM Thread Starter
stormer1092
1994 ZJ
Well this is my situation. My battery gets really low to the point where the jeep barely starts or it goes completely dead over night. I went to oreilly had the battery and alternator tested, the results were Voltage was ok, diodes ok and amperage output was 40 amps with everything off at idle. I also performed a parasitic draw test and got 1.5 mA. Now I'm just kind of lost on what would be happening can anyone point me in a general direction? Oh my battery is 800cca.
stormer1092 is offline
post #2 of 17 Old 05-06-2013, 06:40 PM
durango-bob
2006 WK
You can disconnect the battery overnight and see if it is OK in the morning. That would determine if you have a battery issue or an off draw issue.
durango-bob is offline
post #3 of 17 Old 05-06-2013, 11:15 PM
bullydog22
Sounds like parasitic draw.
-Pull the negative battery cable and run your digital voltage meter on amps between the negative post on the battery and the negative bat. cable end.
-Observe and note the reading
-pull one fuse at a time until you see the reading drop. If you pull one fuse and it does not drop, put it back and and move to the next.
- once you find the fuse that makes the reading drop, you can determine which components are on that circuit and start testing/ replacing them.
GL
bullydog22 is offline
post #4 of 17 Old 05-07-2013, 01:33 PM Thread Starter
stormer1092
1994 ZJ
GL
already did that. 1.5 mA
post #5 of 17 Old 05-07-2013, 01:43 PM
JeepNicholson
So which fuse stopped the draw when you pulled it?
JeepNicholson is offline
post #6 of 17 Old 05-07-2013, 01:47 PM Thread Starter
stormer1092
1994 ZJ
1.5 mA is within acceptable range. I believe.
post #7 of 17 Old 05-07-2013, 03:11 PM
JeepNicholson
Oh right, sorry, misunderstood you there.
post #8 of 17 Old 05-07-2013, 03:16 PM
elf517
Mine does the same thing. My driver door is a little bit off and it doesn't close properly so the interior lights sometimes come back on after i walk away from it and they drain the battery.
elf517 is offline
post #9 of 17 Old 05-07-2013, 03:17 PM
tucsonzj
I was thinking hidden interior light, or possible random draw from audio system after turn off?
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #10 of 17 Old 05-07-2013, 03:20 PM
elf517
Well I don't know about the aftermarket audio system I have had my sony xplode and my subs in long before it became an issue.
elf517 is offline
post #11 of 17 Old 05-07-2013, 05:29 PM
durango-bob
2006 WK
How did this test work out?
post #12 of 17 Old 05-08-2013, 12:12 AM
bullydog22
Something is wrong in your diag. You say batt., alt , parasitic draw all test good , yet you still have a dead batt. in the morning? Cant be.
A draw over about .06 amps can kill a batt. over night. What did you have your DVOM set to when you tested draw? If you have access to, try testing the batt. with a load tester. I've had bad batt. test good with cheap conventional testers like AUTO ZONE uses.
post #13 of 17 Old 05-08-2013, 01:11 AM
Oldfrog
2007 WK
Install the battery, start it up. Now take a digital volt meter and measure the voltage across the Battery terminals ( not the cable clamps, but the battery's terminals). ( 13.5v or better, is about right, as I recall. I think mine is around 14.XX...but 13.5 is probably Ok)
Next, take a reading across the battery cable clamps. The readings should be EXACTLY the same, if the engine is running and you're making good contact with the meter probes each time. If not....then you've begun to isolate your problem.
FYI :
Jeeps hate bad or aging batteries. If it's over 2 years old, you probably need to replace it anyway.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #14 of 17 Old 05-08-2013, 09:28 AM
tucsonzj
FYI :
Not to mention, when one goes wrong all goes wrong.
tucsonzj is offline
post #15 of 17 Old 05-08-2013, 10:36 AM Thread Starter
stormer1092
1994 ZJ
I don't know what was going on with this. The last 2 days everything has been running fine. Maybe some light was left on or the brake lights stuck on or something and I just didn't notice. If it happens again I will update.
