need help asap, search wasnt quick enough - JeepForum.com
post #1 of 6 Old 01-25-2005, 04:20 PM Thread Starter
gregmondro
gregmondro's Avatar
ok guys heres the problem.
im gonna do the tcase and both axle fluids in my Jeep tonight but my friend who works at autozone only is there for a few more minutes (my discount)
my jeep is a 94 with the quadratec system
(4 all time)
neutral
4 lo
i have the tow package with 3.73s
what I need to know is what fluid the front axle, rear axle, and t-case uses
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #2 of 6 Old 01-25-2005, 04:27 PM
Meerkat
In the transfer case, you can use Dexron III or Mercon, but I recommend sticking with ATF+ 3 or ATF+ 4. Use whichever ATF+ you are going to use in your automatic transmission. That way you won't have any confusion about what goes where. The TC uses 2.5 pints.
Front differential uses Mopar Gear Lubricant or equivalent SAE 80W-90 API-GL5 grade. 3.125 pints.
Rear differential uses SAE 75W-140 Synthetic Gear Lubricant. 2.5 pints. If you have Trac-Lok, you'll need an anti-slip additive, but it isn't likely you have Trac-Lok (limited slip differential).
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 01-25-2005, 04:29 PM
DSMjunkie
you never cease to amaze me...your like a FSM on legs
White Jeep Club Member #982
Air Force Jeep Club Member #16
2k8 JK
1997 nissan stagea drift wagon
1998 legacy wagon grip monster
DSMjunkie is offline
post #4 of 6 Old 01-25-2005, 04:29 PM Thread Starter
gregmondro
gregmondro's Avatar
thanks
is there any benefit to using atf 4 over atf 3 for the transfer case?
and also, for the front diff, would there be any drawbacks in using synthetic fluid?
post #5 of 6 Old 01-25-2005, 05:58 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Ladies and Gentlemen,
due to recent bandwith limitations, we ask that all of you refrain from feeding WVD's ego. His head swells to unimaginable limits and the internet can take only so much.
Thank you,
Management.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 6 Old 01-26-2005, 03:12 PM Thread Starter
gregmondro
gregmondro's Avatar
hahahs, so back onto the question?
atf 3 or 4 for the transfer case?
or should I just go with dealer stuff for that.
Quick Quick Quick....Front DS U Joint Removal Darthteddy ZJ Grand Cherokee Forum 3 08-11-2008 12:25 AM
Search is down, quick Q about soft 8's TheSandman ZJ Grand Cherokee Forum 12 03-07-2008 06:22 PM
Quick Quick Question - Mopar CCC Darthteddy ZJ Grand Cherokee Forum 4 12-05-2007 11:40 AM
It wasnt cheap, easy, pretty, or done right, and it kind of smells micifus ZJ Grand Cherokee Forum 11 07-27-2007 04:41 AM
231J/247 TC conversion.. quick,quICK,QUICK! UUJ1 ZJ Grand Cherokee Forum 7 05-25-2007 08:20 PM
