NEED HELP ASAP!!!!! did engine swap - JeepForum.com
post #1 of 10 Old 07-28-2009, 09:46 PM Thread Starter
jim75
i have a 98 4.0. friday night #5 piston exploded.so here it goes, pulled motor out of mine,pulled motor out of a 93 (4.0) put my head, intake,new ex. manifold, my oil pan and swaped distributer. put everything together and started it tonight. Exhaust manifiold glowing BRIGHT red. the exhaust has a strang rumbel to it. and the power lacks. so what gives????
a friend of mine said it is running realy lean, but doesent know why. could i not have it in time? is this what is causing all my problems?
please help this is my DD.
jim75 is offline
post #2 of 10 Old 07-28-2009, 10:15 PM
newfieZJ
The 02 sensor could mess with the mixture , but , given your symptoms , I'd guess a sticking injecter . You can do the screwdriver to the ear method on each injecter or anything that sounds abnormal compared to others, listen for constant clicking . I can't think of anything else other than a restrictive exhaust . Ever do exhaust work to it ? Perhaps the cat isn't heathy
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 10 Old 07-28-2009, 10:31 PM Thread Starter
jim75
the exhaust was fine before i swaped and it has only run about 20 mins. i am kinda stuck thinking it is a timeing issue.
jim75 is offline
post #4 of 10 Old 07-28-2009, 11:12 PM
newfieZJ
Did you remove/change or adjust the distributer ? If so , you could be right . There's just no need to change the dist or mess with the base timing , the cam sensor should have been the only difference because of the plug in itself .
Even the base timing can be compensated by the PCM to a certain degree , you'd probably have to be off by 10 or more degrees IMO to cause much of an issue .
Back to the issue , did this occur idling or after a drive , did you drive it hard to get the manifold red hot . More details might change things .
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #5 of 10 Old 07-28-2009, 11:51 PM
WiCkeDuDe
WiCkeDuDe's Avatar
To be that hot it has to be a timing issue. Way to advanced I would say.
WiCkeDuDe is offline
post #6 of 10 Old 07-29-2009, 12:37 AM
Redrum_1
Some call it a timing issue but its really not. The ignition timing is read by the PCM from the crankshaft sensor and is taken care of by the PCM you can't change that. Now comes the Cam sensor in the distributor you moved the distributor and messed up the injector timing. Ignition timing and fuel timing have to work in the correct sequence in order for your engine to run right. Since I doubt you have access to a DRB III scan tool take your jeep to the dealership and have them put the fuel sync back in time with the ignition timing and all should be well again.
Good Luck...
2013 Dodge Ram 1500 Express Quad Cab. 5.7L Hemi 6 speed automatic 3:55 gears LSD with 20 inch rubber
2000 Jeep Grand Cherokee Limited 4.0L
2003 Nissan 350Z Enthusiast Model 6 speed manual
2002 Audi A6 Avant Quattro 3.0L Auto
Redrum_1 is offline
post #7 of 10 Old 07-29-2009, 12:54 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The dist is 180 out. Take it out and be sure you have number 1cyl at tdc compression and line up the rotor with number one plug post on the dist. Good luck.
Its not something you'll want to mess with in the computer. Always fix it mechanically, the computer obviously didn't change out of nowhere.
ratmonkey is offline
post #8 of 10 Old 07-29-2009, 05:41 AM Thread Starter
jim75
it was just sitting at an idel when i noticed it.
jim75 is offline
post #9 of 10 Old 07-29-2009, 05:55 AM
dobe
Yes I would put the original distributor back in.
dobe is offline
post #10 of 10 Old 07-29-2009, 10:21 AM Thread Starter
jim75
i think i might give it a try...
jim75 is offline
Engine will not seperate from tranny?!? Engine swap 95cherokee33s ZJ Grand Cherokee Forum 2 05-05-2008 10:03 PM
Engine Swap matts98ZJ ZJ Grand Cherokee Forum 5 02-12-2007 01:31 PM
Problems after installing new engine.....Need help ASAP, going to Tahoe this week chriso ZJ Grand Cherokee Forum 4 02-01-2007 04:39 AM
v8 engine swap into zj hagop leon ZJ Grand Cherokee Forum 3 01-07-2005 10:13 AM
Engine Swap jeepboy18 ZJ Grand Cherokee Forum 0 01-01-2005 05:36 PM
