need help - JeepForum.com
post #1 of 8 Old 07-29-2009, 06:51 PM Thread Starter
robiec04wj
need help
My 04 wj has started this nasty lifter knock that keeps getting worse. Sounds like it is coming from the camshaft area on the passenger side of the heep. I have tried seafoam twice but to no avail. It has the 4.0 powertech with roughly 122000 on the clock. Is this a sign of worse to come or does anyone know of an easy fix. The ticking is intermittent ans is loudest near the camshaft sensor( where the distributed would be if it had one) any help would be greatly appreciated.
robiec04wj is offline
post #2 of 8 Old 07-29-2009, 08:52 PM
simidrm
What kind of oil are you using? if your running synthetic then change back to convential oil as synthetic is a thinner consistancy and regular ol 10w30 is a liitle heavier,also try rislone additive it is a upper cylinder lubricant will help if it's just sticky lifters
simidrm is offline
post #3 of 8 Old 07-30-2009, 09:30 AM Thread Starter
robiec04wj
I am using castrol gtx 10w30. I have never had a problem like ths before.
post #4 of 8 Old 07-30-2009, 10:07 AM
StrokedWJ
StrokedWJ's Avatar
Have you dropped the oil pan? Thats about the same mileage my 2000 4.0L had when a piston skirt broke. (That would probably be your "worst case" scenario though)
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 8 Old 07-30-2009, 10:15 AM
kc8ztw
change the oil and run 1 or 2 quarts of atf and the rest 5-30 conventional oil and run that for a little while and see if it gets better. if it just gets worse then you wanna fix it.
ps yes thats right run atf in the oil!
kc8ztw is offline
post #6 of 8 Old 07-30-2009, 10:29 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Sounds like you have the infamos piston slap/knock problem. I had it and lived with it for about 18 months until it got so bad that I could not stand it any more.
I had my engine rebuilt at 168,000 to get rid of it. The 4.0 is pretty well noted for this problem.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #7 of 8 Old 07-30-2009, 11:00 AM Thread Starter
robiec04wj
I guess I could drop the oil pan. It does a have a slight leak around the lip anyway. The only thing is it doesn't sound like piston slap. Has about the same click as pulling a plug wire off a small block chevy and touching it to the block.
post #8 of 8 Old 07-30-2009, 01:15 PM
kc8ztw
you could have the piston slap issue but the analogy you used makes me almost agree with you about the lifter. its always worth the atf thing first cause that cost $20 for an oil change and a few quarts of atf and not a engine rebuild
kc8ztw is offline
