Need Help: 5.9 Limited Starting Issue - JeepForum.com
post #1 of 9 Old 04-15-2010, 11:08 AM Thread Starter
bradtabor
My Jeep was driving fine and just died on me. Then when ever it would warm up it would die again.. I noticed I had no fuel pressure with I checked it at the rail.
I originally figured Crank Sensor, until it wouldn't even start when it was cold. Then I figured Fuel Pump.
So I replaced the fuel pump. Still no fuel pressure and it doesn't even kick on.. However the Relay is still good in the fuse box and even tried a known working one..
Also there is power going to the hot leads of the relay connection in the fuse box when the relay is removed and has the full 12 volts plus just like it should.
I also cleared the computer as well..
Can a bad Crank Positioning Sensor cause a fuel pump not to turn on???
Any Ideas??
bradtabor is offline
post #2 of 9 Old 04-15-2010, 11:18 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the ignition coil. If you have spark, your fuel pump motor may have died. Do you hear it "spin up" when you turn the key to run?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 9 Old 04-15-2010, 11:20 AM Thread Starter
bradtabor
It's my second pump I have tried.
I put a new ignition coil on and the old one tested fine..
The pump doesn't try to even turn and I tested it out of the jeep as well and it worked fine.
Wiring Harness is good..
post #4 of 9 Old 04-15-2010, 11:32 AM
ajmorell
ajmorell's Avatar
Are you getting spark? If no spark and no fuel check the ASD relay.
ajmorell is offline
post #5 of 9 Old 04-15-2010, 11:51 AM Thread Starter
bradtabor
Never hear of that relay.. where is it at??
post #6 of 9 Old 04-15-2010, 12:04 PM Thread Starter
bradtabor
Ok...
No spark..
No Fuel..
Swapped the AC relay out to test Auto Shutdown Relay and Still nothing..
post #7 of 9 Old 04-15-2010, 12:53 PM Thread Starter
bradtabor
No Fuel no Spark no Error codes
post #8 of 9 Old 04-15-2010, 02:28 PM
ajmorell
ajmorell's Avatar
Test power going to the PCM to make sure that relay box is getting power
ajmorell is offline
post #9 of 9 Old 04-19-2010, 10:03 AM Thread Starter
bradtabor
Found out it was the Crank Sensor.. It was melted with exposed wires..
Thanks again guys!!
cps , fuel pump , not starting , tps
Need Help: 5.9 Limited Starting Issue bradtabor WK Grand Cherokee & XK Commander Forum 2 04-14-2010 09:48 PM
94 gc limited radio issue/steering issue? r34civic ZJ Grand Cherokee Forum 7 01-04-2010 06:00 PM
Starting issue. neoncrazy101 ZJ Grand Cherokee Forum 2 11-16-2009 07:54 PM
94 ZJ Starting Issue NEp8ntballer ZJ Grand Cherokee Forum 10 08-05-2008 11:50 PM
Trouble starting my 95 GC Limited! nholmes11 ZJ Grand Cherokee Forum 2 09-14-2001 10:01 AM
