need help!! - Page 2 - JeepForum.com
post #16 of 28 Old 12-07-2011, 09:16 PM Thread Starter
jtackerman28
I checked asd relay .ignition fuse fuel pump relay. Pcm fuse. Just went for runnining ones. Will check others tommarow. I believe it was still no check engine light when unhooked.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #17 of 28 Old 12-07-2011, 11:07 PM
phitmein
phitmein's Avatar
"It is also reading empty on the gas gage while having fuel in it. When I turn the key I can hear the fuel pump running but it doesnt stop running idk"
Just for the heck of it pour a couple of gallons of gas in it and see what happens.
It just seems strange to me that the fuel pump keeps running.
Phit
phitmein is offline
post #18 of 28 Old 12-08-2011, 04:11 AM Thread Starter
jtackerman28
Already did
post #19 of 28 Old 12-08-2011, 06:20 AM
merlot2twisty
The fact that the fuel pump keeps running I think is key here. Since it is only supposed to prime and then stop, and given the strange other behavior, I vote for a short or bad ground somewhere.
merlot2twisty is offline
post #20 of 28 Old 12-08-2011, 01:14 PM Thread Starter
jtackerman28
Gages still read wrong when crank sensor unhooked where to next?
post #21 of 28 Old 12-08-2011, 05:07 PM
ZeeJay1997
If you're not getting a CEL lamp check from the PCM, the PCM is not working (assuming you know the light was working earlier). Since it is sending a ground to the fuel pump relay, it's not completely dead. You can reset it by disconnecting the negative battery cable. After you disconnect it, turn the ignition to start to discharge any residual voltage. Then, take the keys out and put them in your pocket. Then go out and clean your battery cables if you haven't done so lately and reconnect them.
As a long shot you can try swapping the ASD and fuel pump relays with the horn and intermittent wiper relays.
ZeeJay1997 is offline
post #22 of 28 Old 12-08-2011, 08:25 PM Thread Starter
jtackerman28
I did try the second one. Had yad battery unhooked but never had turned it on while unhook will try it. Could it be a possible alternator failure?
post #23 of 28 Old 12-08-2011, 08:50 PM
ZeeJay1997
post #24 of 28 Old 12-08-2011, 08:56 PM Thread Starter
jtackerman28
??? the light was working earlier.... I checked all fuses and unhooked rehooked battery multiple times. Is that a no om the alternator?
post #25 of 28 Old 12-08-2011, 09:47 PM
ZeeJay1997
take battery cables off, pull plugs on PCM, clean them, reassemble and try it.
post #26 of 28 Old 12-08-2011, 09:56 PM Thread Starter
jtackerman28
Should I pull radiator tanl to get the plugs out of pcm or will it be easy with it on
post #27 of 28 Old 12-08-2011, 09:57 PM Thread Starter
jtackerman28
Coolant overflow tank*
post #28 of 28 Old 12-08-2011, 10:33 PM
phitmein
phitmein's Avatar
have you tried spraying some instant start down the TB to see what happens ?
Have you checked for spark and for fuel at the rail ?
phitmein is offline
