need help!! - JeepForum.com
post #1 of 28 Old 12-07-2011, 06:32 PM Thread Starter
jtackerman28
need help!!
Yester day my 1997 4.0 died while driving. It seems to have no spark at all. I just replaced the coil today due to it having several cracks in it and nothing. Has new plugs cap rotor and wires. It is also reading empty on the gas gage while having fuel in it. When I turn the key I can hear the fuel pump running but it doesnt stop running idk if this is normal or not. Any ideas? Thank you I'm trying to avoid halling it to a dealer :/
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #2 of 28 Old 12-07-2011, 07:01 PM
pincheburro956
have you checked the Crank Position Sensor. May be it.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #3 of 28 Old 12-07-2011, 07:06 PM
KoreaZJ
1994 ZJ
Scan it for fault codes to help isolate the problem(s).
KoreaZJ is offline
post #4 of 28 Old 12-07-2011, 07:29 PM
ZeeJay1997
It sound like something has gone wrong with the PCM. A couple of things may be causing it, one is the crank sensor and the other is either of the O2 sensors. The usual failure mode is the PCM will not do anything when one of these shorts out. What you have sounds like a partial failure. Does the check engine light come on for 3 seconds when you turn the switch to the on position? If not, the PCM is definitely malfunctioning.
ZeeJay1997 is offline
post #5 of 28 Old 12-07-2011, 08:20 PM Thread Starter
jtackerman28
It isn't and low fuel light comes one. Both o2 sensors are unplugged to rule that out. Where at is the pcm fuse? Not sure have seen a few diffrent thing. And should I just go ahead and change the crank sensor?
post #6 of 28 Old 12-07-2011, 08:33 PM
ZeeJay1997
have u been wheeling lately? check for shorted wires near drive train. the fuse for pcm is in the power box under the hood. if its blown, the o2 wiring is suspect. the crank sensor is still suspect too unplug it before changing the fuse if fuse is blown.
post #7 of 28 Old 12-07-2011, 08:35 PM Thread Starter
jtackerman28
A lil wheeling nothing to serious. What size fuse is it?
post #8 of 28 Old 12-07-2011, 08:37 PM
ZeeJay1997
i think its small blue 15 amp
post #9 of 28 Old 12-07-2011, 08:48 PM Thread Starter
jtackerman28
I check that and its good. Where from here? Like what should I checl next
post #10 of 28 Old 12-07-2011, 09:00 PM
ZeeJay1997
take ther crank sensor loose connector and see if the 3 second CEL comes back
post #11 of 28 Old 12-07-2011, 09:02 PM Thread Starter
jtackerman28
You mean unplug it? Then check?
post #12 of 28 Old 12-07-2011, 09:03 PM
ZeeJay1997
yes unplug it, turn the switch on, and see if your fuel pump, cel and fuel gage work
post #13 of 28 Old 12-07-2011, 09:04 PM Thread Starter
jtackerman28
If yes whats that mean? If no that also? Thanks for the help!!
post #14 of 28 Old 12-07-2011, 09:05 PM
ZeeJay1997
did you check all the fuses under the hood??
post #15 of 28 Old 12-07-2011, 09:06 PM
ZeeJay1997
your using the process of elimination... if you unplug it and the PCM works, the crank sensor is bad
