Need a flywheel cover/inspection plate. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Need a flywheel cover/inspection plate.
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 03-15-2011, 03:15 PM   #1
rlcii77
I'm missing my flywheel cover for my '94 ZJ 5.2L, 46RH trans.. I noticed it gone after I had the rebiuld on the transmission done. I was hoping I could find it at the shop that did the work, but no luck. I figured if I took it wheeling & mud or anything decided to get up in there, it would eventually cause some sort of damage. Would it? If anyone has one, please get in touch.
Thanks.
rlcii77 is offline   Reply With Quote
Unread 03-15-2011, 03:51 PM   #2
coralman
coralman's Avatar
Put it this way. I don't wheel. On my 42re I discovered mine was gone. NO tranny leaks whatsoever. I dragged my *** going to the jy and getting one because I didn't want to lay up under the jeeps{they are sitting on vertical rims and that creeps me out}. Finally I went and low and behold one was lying on the ground already taken off. TOO LATE. Within a week I had a front seal leak.
coralman is offline   Reply With Quote
cover , flywheel , inspection , plate , zj
