need a door lock motor/servo 1997 ZJ Laredo 4x4 V8 - JeepForum.com
post #1 of 2 Old 07-15-2013, 07:34 PM Thread Starter
webhostingdesig
I need a door lock motor/servo 1997 ZJ Laredo 4x4 V8. The automatic locking doesn't work for my driver's side.
1) how hard is it to take off the door shell?
2) can I just spray something on the servo/motor to get it to work?
3) should I get a used motor or one from online? any recommendations?
webhostingdesig is offline
post #2 of 2 Old 07-16-2013, 05:54 AM
Kingr98
2016 JK Wrangler
Door anel s not hard to take off. I believe there are three screws: one behind chrome door handle, one forward and up, and a third middle down. They all have plastic covers that you can remove with a flattip screwdriver. The screws are all #2 phillips. After that, start at the bottom and pry out on the panel. I used my fingers, but some use a big screwdriver. There are several clips around the edge of the panel that have to be released. Some of them will probably break.
After it is loose all the way around, slide it up a little to get it out of the window track. When it is free look behind it and disconnect the connectors.
I recommend getting a replacement from the jy. This way you get practice removing a door panel and an accuator before you start tearing yours apart. Be sure to clean up the jy part with WD40 (I used q-tips to reach inside as much as possible. Then grease it.
Kingr98 is offline
