Need to do a trans pan reseal, any tips? - JeepForum.com
post #1 of 14 Old 07-14-2014, 10:10 PM Thread Starter
PTECH
The pan on my 98 V8 is leaking. I want to get that fixed that so I can park in my driveway haha. I thought I've read about people upgrading or switching to a different pan? It looks like I have the stock pan and some type of RTV was used to seal it but it didn't do a very good job. I thought I recalled coming across a thread saying there was a factory jeep gasket that worked well but maybe I'm mixed up. I would like to get this leak corrected even if it means spending a few extra bucks to do it right. Whats the best way to get this fixed?
PTECH is offline
post #2 of 14 Old 07-14-2014, 10:16 PM
riot1987
Ive read some about getting a different, better pan. These ones are thin and I think tend to warp- especially when you drag em over a bunch of rocks and ****. I think a common problem is people over tightening the pan bolts. Itll smoosh out the gasket and loose the seal. Get a torque wrench
Build thread^^
riot1987 is offline
post #3 of 14 Old 07-15-2014, 08:22 AM
KJK
Get a new pan. Get the factory re-usable pan gasket. It's plastic with a rubber o-ring type sealing surface. Don't use any RTV or other stuff on it.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #4 of 14 Old 07-15-2014, 09:23 AM Thread Starter
PTECH
Awesome, thanks.
PTECH is offline
post #5 of 14 Old 07-15-2014, 10:17 AM
KJK
I've had the same one for years and it's been on and off many times for other trans jobs and it still doesn't leak a drop. You could put a straight edge across your existing pan once it's off and see if it's deformed at the pan rails or not.
KJK is offline
post #6 of 14 Old 07-15-2014, 10:23 AM Thread Starter
PTECH
I ordered a new one anyways, mine has some dings in it. 20 bucks from Jeep for a new one. Hell the gasket almost costs more than the pan haha.
PTECH is offline
post #7 of 14 Old 07-15-2014, 11:42 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yep, pan and the mopar gasket, torque is only like 13ft lbs on the bolts so don't over tighten.
http://www.jeepforum.com/forum/f13/n...l#post23796562
kg6mov is offline
post #8 of 14 Old 07-15-2014, 11:59 AM
PolkaPower
RTV around the bolt holes. That's where is usually leaks.
PolkaPower is offline
post #9 of 14 Old 07-15-2014, 12:52 PM
T-nave
Do yourself a favor and get a small torque wrench. Mine will go down to 14 but in the manual it says its only good down to 20 and they were right.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline
post #10 of 14 Old 07-15-2014, 01:10 PM Thread Starter
PTECH
I have a 1/4" and 3/8" snap on torque wrenches
PTECH is offline
post #11 of 14 Old 07-16-2014, 06:30 AM
970001zj
use a jack to hold the pan up so you can align the gasket better
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #12 of 14 Old 07-16-2014, 06:37 AM
Scopez
1994 ZJ
After all these pan gasket replacements, I never once thought about that.... Good tip.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #13 of 14 Old 07-16-2014, 09:27 AM
MKCoconuts
High tac is a good option as well. It'll keep the gasket in place while fitting the pan. Used it many times for different gaskets and has never let me down.
MKCoconuts is offline
post #14 of 14 Old 07-16-2014, 11:03 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
If you use an ATP gasket, there are four tabs on the gasket. The hole near each tab is smaller and will hold a bolt and that keeps everything aligned for installation.
HighLonesome is online now
