need confirmation that fuel sending unit will fix erratic guel gauge - JeepForum.com
post #1 of 7 Old 06-13-2012, 03:01 PM Thread Starter
tcabello
I have 98 zj and have replaced the pcm a while back...I had all the standard issues, stalling, dying, hesitaiton, etc, etc...jeeps seems to better since pcm has been replaced...it did stutter once on a 3hr trip but hasn't done it since...
however, my fuel gauge is acting weird...usually with 1/4 of a tank left (more or less) the guel guage drops to E and the low fuel light goes on...then it jumps back to normal...
before y'all say to do a search...i did...just spent about 45 minutes looking through old threads...however, I didn't find any concrete answers...a couple of threads suggested the gauge cluster be replaced and others suggested the sending unit on the fuel pump was the problem...but I didn't read a single thread that gave a difinitive answer...
(oh, and I also read how a bad pcm might be the culprit, which worries me and makes me think i might have to replace pcm again)
so, has anyone solved this problem??
Thanks
tcabello is offline
post #2 of 7 Old 06-13-2012, 03:48 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Mine was doing that. The pump was going too so I replaced the fuel pump module. Problem fixed.
coralman is offline
post #3 of 7 Old 06-13-2012, 04:05 PM
Technohead
Yes, it typically fixes the problem. But as with all things in life there is never any guarantee.
-Eric
Technohead is offline
post #4 of 7 Old 06-13-2012, 04:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's a standard chrysler sending unit issue. vehicles from the 90's through 2006 or so do it straight from the lot.
new sending unit will probably fix it, but not always.
ratmonkey is offline
post #5 of 7 Old 06-13-2012, 05:23 PM
coralman
coralman's Avatar
I could be wrong but I don't think the signal from the unit directly feeds the gauge. It goes into the bcm or pcm also I think. So yep, could be more to it than just the unit.
coralman is offline
post #6 of 7 Old 06-13-2012, 06:27 PM
cootertwo
1997 XJ Cherokee
My 97 4.0 also does the same exact thing. I figure it's the sending unit, in the tank. You gotta figure the gas sloshing around when below half a tank, constantly works the sending unit, and eventually (170,000 miles on mine) wears that particular place out. I'm used to it by now, and considering the cost of a new pump/sending unit , not to mention having to drop the tank to do it, I'll just wait till the pump gives out first. I too, have a reman ECM/PCM, and it had no effect on the gauge problem. Just one of those MANY jeep things. But, I think we tend to forget just how old, and how many miles we have on our rigs. Most any vehicle with over 150,000 miles will also have a ton of problems. I do wish we had less computerized crap, but we got what we got. I would have never guessed that a 1997 vehicle would be so advanced with all the sensors, etc. etc. Like for instance, how many vehicles have a temp sensor under the battery? Or a low washer fluid sensor, low coolant tank sensor, etc. etc. When they all work, it's wonderful. When they don't, it can be a nightmare.
cootertwo is offline
post #7 of 7 Old 06-13-2012, 10:15 PM Thread Starter
tcabello
thanks for the advice...I guess I'll just wait 'till the fuel pump gives out and hope that fixes the fuel gauge...it really isn't that bad, it only acts weird at about he 1/4 tank mark...above that it's fine (so far)...I'm not ocd or anything, but I do like my cars to perform as they should, especially an older vehicle because people expect things to be wrong and are surprised when older cars look and perform well...
well thanks again and y'all have a good one.
tcabello is offline
Coolant Temp Sending Unit - to dash/gauge (not computer) Oxenhandler ZJ Grand Cherokee Forum 16 04-26-2015 01:27 PM
Trans Temp Gauge install w/factory sending unit iflypa28 ZJ Grand Cherokee Forum 7 07-13-2013 01:05 AM
ZJ Fuel Gauge sending unit? but DIC says other wise... porrsher ZJ Grand Cherokee Forum 5 10-26-2010 05:03 PM
4.0 possible fuel injector problem or fuel sending unit metroman ZJ Grand Cherokee Forum 2 08-15-2009 02:37 PM
Oil Gauge Sending Unit rebel517 ZJ Grand Cherokee Forum 30 01-29-2008 08:57 AM
