Need to change out my sister 2004 passenger side tailight , steps to change it? - JeepForum.com
post #1 of 4 Old 09-27-2005, 03:37 PM Thread Starter
chaznad
i have a 97 wrangler and do my own work, but her vehicle is much more complicated looking, electrical and stuff then mine and i dont want to screw anything up
i have the new passenger side tailight sitting in the box and the bad ones still in her jeep which is an 04 grand cherokee ( the regular one)
any steps u can give
97 TJ 4.0 , 3spd Auto , D30/44 , 3.25 RC lift w/ 1.25" BL / MML , ( 5 )33x12.50x15 Goodyear Duratracs
“Too many people spend money they haven't earned, to buy things they don't want, to impress people they don't like.”
chaznad is offline
post #2 of 4 Old 09-27-2005, 03:42 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Haven't done this myself but I watched part of someone taking out their taillight. They removed the 1-2 screws holding in the light and then pulled hard. It had some clips or something that hold the light in even w/o the screws. Then I imagine that you can just unplug the wiring and plug in the new one Maybe splice but that shouldn't be hard.
This is assuming that you are talking about the whole module.
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 4 Old 09-27-2005, 04:03 PM
oucrazy
Unscrew the two screws. As you pull the tail light assembly away from the body of the vehicle, it will appear that something is not disconnecting. If you bend it down a little , you will be able to see that it is a rubber clip that is holding it. Hold the assembly tightly and firmly pull. It will release and then you can see how it was held in. Good luck.
oucrazy is offline
post #4 of 4 Old 09-27-2005, 06:51 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
Here you go.
http://www.wjjeeps.com/lamps/taillightrem.jpg
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
how often does a 2004 Jeep Grand Cherokee WJ need an oil change aprocknow ZJ Grand Cherokee Forum 13 02-04-2010 08:06 PM
Trans fluid - to change or not to change? pzappa ZJ Grand Cherokee Forum 21 01-08-2010 08:47 AM
oil change and coolant change thudson331 ZJ Grand Cherokee Forum 7 10-19-2007 05:51 PM
To change or not change fluid Sfrid073 ZJ Grand Cherokee Forum 5 07-18-2007 12:34 PM
2004 Fluids change, what specs? Jetjock16 ZJ Grand Cherokee Forum 3 11-08-2005 07:51 PM
