Need advice on WJ tuneup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Need advice on WJ tuneup
Poison Spyder to donate 10% of Memorial Day W/E Sales to RNEW JK All Terrain Bumper and X-Style Stryker Stinger - 20XJ guys, clock your transfer case!
Unread 03-09-2009, 08:49 AM   #1
Skout41
I just recently purchased my first Jeep a 2004 WJ limited with 4.7L V8 with 63,000 miles on it.
I bought it from a local used car dealer around here and I am not very sure what all has been done to it recently in terms of maintenance. So considering this I would like to give it a pretty comprehensive tune up.
What would you guys recommend that I do?
So far on my list I have:
diff oil
tranny oil
transfer case oil
new spark plugs
check air filter
check O2 sensors
Clean fuel injectors
What else should I do? This is my first time doing a tune up for myself so I have a feeling I may be overlooking something....
Any advice you guys have for me would be awesome to hear!!
Skout41 is offline   Reply With Quote
Unread 03-09-2009, 09:07 AM   #2
Turbonut
Here's a list of the correct replacement parts, and don't substitue the spark plugs, the 247 T/C fluid, or the ATF+4 trans fluid, and also note the addition of a friction modifier if QD:
http://www.wjjeeps.com/service/maintenance_wj.htm
Note: Two trans filters
Forget the O2 sensors and fuel injector cleaning as they will tell you if service is needed.
Have fun
Turbonut is offline   Reply With Quote
Unread 03-09-2009, 09:13 AM   #3
trailblaze
looks pretty good.
you hit all the areas! when doing the tranny, change the filters.
Matt
trailblaze is offline   Reply With Quote
Unread 03-09-2009, 09:15 AM   #4
trailblaze
ohh check the brakes ..
and grease the fitting too.
Matt
Unread 03-09-2009, 09:45 AM   #5
Skout41
Alright, I was planning on checking the brakes, I just forgot to put that down. But thanks for the heads up on the transmission filter!
