Need Advice: Replacing the rear end. - JeepForum.com
post #1 of 5 Old 06-03-2003, 11:24 AM Thread Starter
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
97' GCL, I-6, 242 t-case, No drivetrain or suspension mods.
Ok, so the time has come to completely replace my rear end assembly. About 60k miles ago I had the differential serviced and rebuilt with the exception of the ring and pinion gears (service tech said that although they would be noisy due to a previous improper grinding session that they had together they would otherwise be fine). This was not the case and now I'm looking at doing the rebuild all over again or replacing the rear axle assembly with a salvaged unit.
Here is my question:
Do I put in another Dana/Spicer 35 or do I replace it with something else? Dealer wants $1800+ to do the rebuild and a salvaged assembly is $800. I could probably do the rebuild myself, but I'm nervous about getting the torque and back spacing settings correct.
* I would one day like to do some off-roading with this vehicle. At which time I would be looking to mod the suspension and wheels. Does it make more sense to replace the assembly with a stronger one now or do it later? What is a good replacement for the current assembly? I'm aware of gearing the front assembly to match that of the rear.
Advice?
Thanks!
Brian
Brian's 97 ZJ is offline
post #2 of 5 Old 06-03-2003, 12:04 PM
5.9ZJPR
That's a big question. I assume you don't go off-road since no suspension mods, so heavy-duty reliability isn't an issue. Do you tow trailers? If I were you, I'd probably find a top-notch rear-end guy to rebuild a D35 or a D44. Don't go back to the dealer.
'98 White 5.9 ZJ, ASD's, Towing Package, 3.5" RE Lift, OME Shocks, Rusty's TC Skid, OME Steering Stab, MOPAR Steering Skid, 245-75/R16 Pirelli Scorpion A/T's on stock 16 x 7 wheels, Rusty's Front Tow Hooks, Kevin's Sliderz
5.9ZJPR is offline
post #3 of 5 Old 06-03-2003, 01:35 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Dude,
I second what 5.9 said. IF you want more strength, you could even go with a super 35 for a complete replacement for less than that stealership price.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 5 Old 06-03-2003, 01:54 PM Thread Starter
Brian's 97 ZJ
Super 35?
After this problem is corrected (again) I believe the stealership and I will be going to court. I (and others) have had trouble with poor service work from them. Here is the current situation with them: I took it in to have the rear output shaft seal replaced on my t-case for the 3rd time (housing was cracked and they had missed it on the first 2 attempts at repair). During this repair, the noticed that the shaft seal on the front differential was leaking and replaced it (without my knowledge or consent). I left the dealership that night and noticed it was making a quiet, but different, noise than just the rear end grinding. After getting it home, I had to make a quick trip to my fiance's house. Upon backing up, the drivetrain was making a horrid grinding sound now coming from the front! (Note: At this point in time their service tech had not messed with the rear end at any time, only the t-case and the front diff seal.) So I call them up and explain the situation, take it back and they tell me that the rear is transferring the noise through the drive train and that it won't go away until I repair/replace the rear assembly. They won't even look at the front end to see if their tech screwed something up on the seal replacement (lost a shim, whatever...).
If you can provide me with either links or contacts to companies that can help, it would be greatly appreciated.
Brian
post #5 of 5 Old 06-04-2003, 04:17 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Brian,
sorry to hear about your drivetrain. Lots of grand owners do acles swaps to increase the durability and strength of the drivetrain. The super 35 is a kit that includes axles and usually a detroit locker.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
Replacing T-case Shift motor - need advice OurayWK WK Grand Cherokee & XK Commander Forum 23 04-17-2014 08:36 PM
Replacing my computer: Need advice. arth ZJ Grand Cherokee Forum 2 06-03-2008 04:48 PM
Replacing Steering Gear- Advice? JayIV ZJ Grand Cherokee Forum 4 08-17-2007 11:47 AM
Replacing Pinion seal on a Dana 30! Any help? Any Advice? What to do? What Not to do? Polaris Junkie ZJ Grand Cherokee Forum 1 09-07-2006 11:46 AM
Replacing header... any advice/ tips? PumaZJ ZJ Grand Cherokee Forum 11 07-07-2006 10:21 PM
