Need 96 4.0 belt diagram - JeepForum.com
post #1 of 10 Old 11-16-2013, 04:46 PM Thread Starter
Cobra Jeep
On a 96 ZJ, it has the solid mounted PS pump with the small tensioner idler below it. There is the AC compressor, the idler between it and thermostat housing, the alt, and then kinda next to the alt is another idler bolted on with one of the timing cover bolts. I have google searched but I am unable to find the correct diagram. All the diagrams I find do not show the idler that is next to the alt. Or, the ones that do show that idler, do not show the one that below the PS pump used to tighten the belt.
Can anyone help? Does anyone have a picture showing the front of the 4.0 with the belt on it of a 96 ZJ?
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #2 of 10 Old 11-16-2013, 05:02 PM
JasonStebbins
Does this help you? It's dark here so I got the best ones I could.
Poop
JasonStebbins is offline
post #3 of 10 Old 11-16-2013, 08:57 PM
Gazang
Cobra,
Thinkin this is what you meant... it seems to jive with Stebbins' above:
http://www.google.com/imgres?imgurl=...ed=0CDkQ9QEwBQ
Hope it helps,
GO JEEP!
JS
Gazang is offline
post #4 of 10 Old 11-17-2013, 07:23 AM Thread Starter
Cobra Jeep
Is that how it is supposed to be from the factory? So there is not supposed to be a idler pulley next to the alt bolted to the timing cover?
Thanks for the pictures jason, those do help!
post #5 of 10 Old 11-17-2013, 08:31 AM
ZeeJay1997
yes, there is a pulley there inboard and below the AC. it is shown in the diagram and jasons pic.
ZeeJay1997 is offline
post #6 of 10 Old 11-17-2013, 06:14 PM Thread Starter
Cobra Jeep
No, I'm talking about one bolted to the timing cover next to the alt. You can see it in the pics in this thread: http://www.jeepforum.com/forum/f13/i...y-shot-576556/
post #7 of 10 Old 11-17-2013, 07:31 PM
JasonStebbins
Very strange. The only thing I can come up with is that pulley was put there for the A/C bypass routing.
Poop
post #8 of 10 Old 11-17-2013, 07:54 PM
ZeeJay1997
those pics were taken from the bottom... still doesnt explain why we cant figure this out... do you have an air conditioner?
post #9 of 10 Old 11-17-2013, 07:59 PM
ZeeJay1997
mine is mounted to the AC bracket, maybe a 96 is different
post #10 of 10 Old 11-17-2013, 08:03 PM
SDHarleydad
1994 ZJ
this is my 94 I6 if it helps...oops just saw your difference...sorry
Casper
1994 JGC Laredo
SDHarleydad is offline
