name that sensor - JeepForum.com
post #1 of 12 Old 10-13-2013, 11:46 PM Thread Starter
97ZJ_FOORx4
name that sensor
What's the sensor on top of the engine near the bolt that adjusts the idler pulley on the 4.slow? While adjusting my belt tension on my grand I noticed that it was loose, like the part that goes into the engine not where it disconnects. Looks like it might be on the water pump.and near the valve cover IIRC.
97ZJ_FOORx4 is offline
post #2 of 12 Old 10-13-2013, 11:49 PM
xcaliber81
A picture says a 1000 words.
xcaliber81 is offline
post #3 of 12 Old 10-14-2013, 12:04 AM Thread Starter
97ZJ_FOORx4
It's 2am here. I'll try to snag a pic on break. Usually my phone takes too big of a picture and it won't upload on here. It doesn't say anything about it on the Vic aside from the usual coolant sensor bad message, but that's always been there.
post #4 of 12 Old 10-14-2013, 12:06 AM
xcaliber81
Unplug it and see what happens lol
post #5 of 12 Old 10-14-2013, 12:10 AM Thread Starter
97ZJ_FOORx4
My check engine light comes on
post #6 of 12 Old 10-14-2013, 01:18 AM Thread Starter
97ZJ_FOORx4
The one right above the belt. With the hoses going into the same piece
post #7 of 12 Old 10-14-2013, 01:56 AM
Uniblurb
Uniblurb's Avatar
Coolant temp sensor in the thermostat housing which sends a signal to your temp gauge in the dash cluster. Was it leaking coolant when loose? When adjusting or removing/installing the belt it's best to disconnect the connector to it since it seems to be in the way with an extension. But that's not what it made it come loose from the housing and someone must have just not tightened it enough.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #8 of 12 Old 10-14-2013, 02:27 AM Thread Starter
97ZJ_FOORx4
Nope no coolant leaking. I can pull on it and see two little wires going into the housing. I prolly knocked it around and it came loose with me adjusting the belt/ trying to disconnect the sensor. It's not loose like I could unscrew it. Its loose like I could pull the wires out of the sensor.
My temp gauge still works even though it's like that lol.
post #9 of 12 Old 10-14-2013, 05:48 AM
ZeeJay1997
if you mean the locking tab is broken off the connector, I wouldn't worry about it as long as the connector has a friction fit with the sensor. You dont want it to bounce out and get caught in the belt/fan.
ZeeJay1997 is offline
post #10 of 12 Old 10-14-2013, 06:31 AM
newfieZJ
Tape it
newfieZJ is offline
post #11 of 12 Old 10-14-2013, 11:18 PM
eagsc7
1994 ZJ
Sounds to me like you've broke the ceramic in the sensor. I'd almost bet that your CEL is on. This sensor sends the temp to the computer for various reasons. I'd get it replaced when you can.
Yeah... your temp gauge would still work. The sensor for that one is by the firewall. It's behind the #6 cylinder on the Drivers side. Has either 1 or two wires attached to it.
My Build Thread: http://www.jeepforum.com/forum/f13/steaks-zj-build-repair-thread-1552698/
eagsc7 is offline
post #12 of 12 Old 10-15-2013, 02:38 AM
Uniblurb
Uniblurb's Avatar
Hmm... Believe on the OBDII 4.0 engines, 96 and up, there is only one engine coolant temp sensor on the thermostat housing. And this is where the temp gauge receives receives the coolant temp signal passed through the PCM.
So your 94 would have 2 coolant sensors where the rear one would supply info to the temp gauge. But on the original poster's 97 4.0 there would only be one engine coolant temp sensor like on my 96. Someone can correct me if I'm wrong but there's no mention of 2 coolant temp sensors in the 96 FSM.
Agree, the temp sensor on the T-stat housing should be replaced if there's a CEL on and they're aren't very expensive. Teflon tape and/or gasket sealer/maker is a good idea on the threads if replaced to prevent leaks.
