Name that chirp - JeepForum.com
post #1 of 10 Old 09-10-2013, 07:02 PM Thread Starter
Fookn4x4
Name that chirp
Replaced water pump and both idler pulleys. Still constant chirping at 2k+ rpm. Won't do it cold but will when warmed up. Any ideas?
Fookn4x4 is offline
post #2 of 10 Old 09-10-2013, 07:06 PM
wwch99tj
The bearings in my alternator chirped just like your describing...
Mine was on a wrangler tho.
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 10 Old 09-10-2013, 08:12 PM
jabba974
Could be some coolant in the alternator, just needs to dry out...Or a bad tensioner...Get yourself a mechanics stethascope and check around the engine compartment.
jabba974 is offline
post #4 of 10 Old 09-10-2013, 09:15 PM
PolkaPower
All you really need is a long screw driver or long dowel rod. Put one end to your ear and the other on the part you are listening to. You will easily tell where it's coming from.
PolkaPower is offline
post #5 of 10 Old 09-11-2013, 05:36 AM
newfieZJ
My vote is on the belt . Try spraying a little water on the belt to test it while warmed up and running when making the noise
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #6 of 10 Old 09-11-2013, 07:10 AM Thread Starter
Fookn4x4
Thanks for the help. Used a mech stethoscope and it's the alternator making the noise. The pulley gets super hot too after idling for only a few minutes.
Fookn4x4 is offline
post #7 of 10 Old 09-11-2013, 07:12 AM Thread Starter
Fookn4x4
I'm starting to believe Jeep stands for "Just Expect Every Penny"
Fookn4x4 is offline
post #8 of 10 Old 09-11-2013, 08:08 AM
Scopez
1994 ZJ
Just empt every pocket.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #9 of 10 Old 09-12-2013, 12:40 AM
Speedymcracer01
Jeep "just empty every pocket" but it'll run practically for ever if you do,long as you don't abuse it often
Speedymcracer01 is offline
post #10 of 10 Old 09-13-2013, 09:05 PM
rbrweb
Mine had the same noise and i change the idle pulley, that stops the noise at the begining, after 2 weeks the sound came again and i had to change the harmonic balancer, that solution the problem definetely.
Bob 232 WCCMx
rbrweb is offline
