N6MZV Build Thread (By kg6mov) - Page 9 - JeepForum.com
 4Likes
post #121 of 385 Old 05-13-2013, 08:37 PM
tucsonzj
liking the bumper man. looks like ya'll had some fun wheeling. I wish I had a welder haha.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #122 of 385 Old 05-13-2013, 10:23 PM
riot1987
Originally Posted by kg6mov View Post
Well here we are again. Was pulling out of my parking spot ready to go home. Wubwubwub THUD.
Attachment 625973
I am 30009% done with this power steering crap.
Put the shorter belt on, drove home without power steering, again. Put air in the niners tires so I can use it to get to work tomorrow.
What polka said yo.
Your problem is spelled out on the front of that pully in 5 big capital letters
Build thread^^
riot1987 is offline
post #123 of 385 Old 05-30-2013, 07:32 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
A minor miracle occurred, I was posessed by some spirit to clean the ****ing garage. You can almost fit an integra in that space, damn. I'm threatening a motorcycle lift, and well, something to go on it.
On to the real fun, grabbed a new (reman) power steering pump and all new hoses, and yet another chinois pulley.
The old one had seen better days, I keep saying I'm gonna get the engine bay steam cleaned, but other things keep taking my $$$.
Comparison.
Only on my second pump bracket, though the first one died in spades. If it goes again I'm gonna have our machinist make me a better one.
Mounted up fine, flushed some fluid through the box and tightened things up. DAMN, thats an impressive difference. Suddenly I can turn the wheel. I probably should have done that when I blew the first pulley, the pump must have been seizing all this time and that was causing the pulleys to be ejected.
Got some new shiny in from superbrightleds.com a pair of these, and some interior lights. Grabbed some scrap 3/16 and welded tabs to the front bumper.
Mounts up nice.
Connected to the factory foglight harness with the connectors off the factory fogs I smashed on the rocks. Because these modules have a full controller in them they do not change brightness with voltage, as the voltage drops they just draw more current to keep things going, then flick off. It's a little weird at first. They're brighter than the factory headlight IMO, makes me really want to do e-codes and harness on this thing.
Finally stripped the back end apart for damage assessment from the crash.
Tow hitch is undamaged except the electrics box, haven't decided if I care. The skid was bent up quite a bit.
Beat the skidplate into shape with the BFH good as new, went down to the JY and grabbed a new rear bumper x-member thing, and new brackets. The plastic cover is ok, haven't found a step guard thing in good condition, really needs it.
Running without the hitchplate, but the skid and bumpers are there. I'm on the fence on the hitchplate, I need to do something about rear recovery and now that I've opened the bumper up and seen how flimsy the aluminum x-member thing is, I'm thinking more about a real steel bumper.
Wheeling again late july, I've got time, but I've got a niner sucking funds and a "new" DD that hopefully will keep my gas costs down a bit.
kg6mov is offline
post #124 of 385 Old 05-30-2013, 08:35 PM
eagsc7
1994 ZJ
Oooo!! A Garage! I need one of those to do some Serious work on my ZJ. Course, IF I still had a garage, then I'd be doing a Tranny swap myself.. be that a good or bad thing.
eagsc7 is offline
post #125 of 385 Old 05-30-2013, 09:31 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Yeh sometime soon I'm gonna end up parking the integra in there for a week while I do the clutch and flywheel and maybe most of the gaskets in the engine.
kg6mov is offline
post #126 of 385 Old 06-15-2013, 08:54 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Finally joined the A-pillar light club.
Little led's are way brighter than I thought they would be, mounts were easy to make. Now I just need to clean up the wiring.
kg6mov is offline
post #127 of 385 Old 06-18-2013, 09:21 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Was using the jeep at work today and I noticed the passenger lower front CA is bent, damn. Not a surprise the way I wheel, but annoying. Is there any way to strengthen the stock CA's? I don't want to get better short arms just to toss them for long arms in the winter.
Plan of attack for mods:
Before the next wheeling trip (July 20th):
  • New lower front CA
  • Rock slides (3x3 box tube under the rockers)
  • T-case skid (3/16 plate)
  • Rear bumper if I find a design I like
  • Fix up lights
  • Replace the antenna mount bracket
  • Rear recovery point
Then:
  • HP30 w/ Artec truss
  • Lunch the back
  • IRO Long arms
  • 4.5" springs
  • Fender trim or flares
  • 33's or 35's
  • XRC8 w/ synthetic rope
kg6mov is offline
post #128 of 385 Old 06-18-2013, 09:24 PM
cgcarpenter
Just get a decent one from the junkyard.
Otherwise you'd just be wasting your time trying to strengthen the stock ones.
cgcarpenter is offline
post #129 of 385 Old 06-18-2013, 09:27 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Yeh I figured, I'll grab one off rock auto, I don't want to play swap the bushing and they're cheap.
kg6mov is offline
post #130 of 385 Old 06-19-2013, 08:08 AM
PolkaPower
They make control arm skids to bolt or weld on. What I would do is get some scrap C channel and cut it at an angle then weld it on. It will stiffen it up and protect the arm. I did that on my last ZJ after I ripped a lower mount off. http://www.quadratec.com/products/12529_200.htm
PolkaPower is online now
post #131 of 385 Old 06-20-2013, 10:44 AM
ARTEC
Vendor
ARTEC's Avatar
We make a factory replacement that's 1/4" and has an integrated skid plate.
http://www.artecindustries.com/Dana-...air_p_372.html
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #132 of 385 Old 06-20-2013, 12:20 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
It's not the bracket as far as I can tell, it's the ****ty stamped metal arm that I set down on. New one ordered and I'm gonna start looking for an hp30 to truss and build to prepared for LA's.
Sent from my iPad Nano using JeepForum
kg6mov is offline
post #133 of 385 Old 06-20-2013, 12:29 PM
PolkaPower
Would you get a night shot of the pillar mounted led's for us please?
post #134 of 385 Old 06-20-2013, 12:45 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
I will, I need to do a comparison of the factory fogs, led fogs, e codes, us heads, and a pillar LEDs. Haven't got the wiring on the a pillars cleaned up yet though.
kg6mov is offline
post #135 of 385 Old 07-21-2013, 06:53 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Oh wow, I haven't updated this in a while. Much to say, we'll start at the beginning.
Finally pulled that control arm that was bent. Really bent. Here it is next to my new one from 1aauto.
Which would have been great if the new one fit. The frame side bushing was too small on the new one they sent me, the frame mount wasn't going to flex enough to torque down on it and me be happy. So I went out to o'reily's and got an arm from them. Same problem. The arms from o'reily's and 1a are symetrical, same bushing width on both ends, the one I bent is wider on the frame side. The weird part: the arm that I bent was purchased from 1a in january when I was rebuilding the front end. I pulled the (maybe stock) arm off the niner to compare.
Here's a comparison shot, from left to right: niner, o'reily, 1a, bent.
Frame side is up on that picture, you can see a slight difference in the bushing. I ended up putting the bent one on the niner and the niner one on the green jeep since the niner doesn't have a lift or get wheeled.
Has anyone else had this problem? Is it a variation in the model years that 96+ had a wider frame side mount? Where can I get a new arm?
kg6mov is offline
build thread , v8
