N6MZV Build Thread (By kg6mov) - Page 7 - JeepForum.com
 3Likes
post #91 of 383 Old 04-20-2013, 04:29 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
This is old, but I didn't post it. Replaced the wheel hubs in the front because one was shaking.
And found out my mechanic had done this.
Those brake pads are on the wrong side of the jeep.
So new brake pads on the front, maybe that will fix the squealing I was getting on the dusty trails.
kg6mov is offline
post #92 of 383 Old 04-20-2013, 04:40 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Alright, bumper time, finally.
Got me some of this.
2x3 1/4 wall tubing to go in the frame rails, and a 4x4 1/4 angle for a new front x-member and part of the winch plate.
Broke out the sawzall and opened up the front of the rails.
My jeep has a fair bit of front end damage, so in addition to the x-member being bent the frame rails are a little squashed.
And won't fit the tube.
So, grab a smaller pipe.
Bash it in.
And use it as a lever to straighten out the rails.
Grab a slightly larger pipe.
And continue the persuasion process until the tube fits.
All better.
kg6mov is offline
post #93 of 383 Old 04-20-2013, 04:47 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
I hit the nuts that were factory welded for the radiator support and popped them off, well I only had to hit the front, the back ones had both come off.
The radiator vertical bolts and the lower side bolts are where my tube will be bolted in, the tube will have nuts welded inside it. Since I have the KOR radiator support there will be 1/4 of steel on both sides of the frame rail sandwiching it together for the mount. Not gonna go anywhere.
Finally put this where it belongs.
Cutting 1/4 wall tube with only a grinder and a sawzall isn't fun, but it works, I think I got things reasonably square.
Mocking the frame mounts. The tube extends 9" into the frame rail (the depth at which the sway bar nut prevents it from going further) and is 7" out from the x-member to support a winch (standard depth seems to be 7").
Mocked and squared the new x-member. About to tack it in this picture.
And pulled to run beads. My welds aren't the best, but once I got it dialed in it wasn't that bad.
kg6mov is offline
post #94 of 383 Old 04-22-2013, 02:03 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Marked out the lower holes for the frame rail mounts. Scribed with a center punch because it was what I had handy.
Here's with the bolts installed to check the threads. I had to break off and adjust one of the nuts when I test fit, but everything else worked. Welded the nuts solid to the tube.
Then I tried to move on to the tube part of my tube bumper (well pipe technically)
Got out this to see if it would bend my 1.5" schedule 40 pipe to a 90.
Nope.
I tried a couple other things but I noticed that after one bend the die had been deformed and wasn't going to give me anything useful. So I gave up and decided to try mitering and welding the pipe.
I'm using a metal cutting blade on my (wood) chopsaw to cut miters.
I got about 80% through the first cut before the bearings on the saw started grinding. Bugger. Gave up for the evening, need a new plan.
kg6mov is offline
post #95 of 383 Old 04-22-2013, 02:10 PM
riot1987
Its gettin there man. Cutting metal took its toll on your poor saw from the sounds of it. Its tough cutting good lines with a sawzall but that may be your best option with the tools you have. I (luckily) had a band saw. Whats that welder? 220?
Build thread^^
riot1987 is offline
post #96 of 383 Old 04-22-2013, 02:26 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Its a 110 lincoln 140 mig. My entire garage is on one 20A circuit, lights, stereo, tools, beer fridge, everything. So I run a cable from an unused circuit in the laundry room.
I think I'm gonna end up with making some marking jigs and using the sawzall. Probably going to modify the design a bit though before I do that.
kg6mov is offline
post #97 of 383 Old 04-22-2013, 02:27 PM
riot1987
Crank up the heat. Really burn that **** in there
Build thread^^
riot1987 is offline
post #98 of 383 Old 04-22-2013, 03:15 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
I've hit the duty cycle limits a couple of times already. Full power and slow feed.
kg6mov is offline
post #99 of 383 Old 04-23-2013, 02:02 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Antenna relocation
As part of prep for wheeling on the 4th I decided it was high time I removed the post hole digging attachment.
The hitch is a bit low, so on rough terrain I'm dragging it into the dirt and leaving ditches. Wonderful mount for street and dirt roads, what we originally bought it for. I also don't like the nice centered spike when I'm unloading my sound ****. I'm worried I'm going to put it through a road case.
Beefy mount though, went right through the radiator of the last ***** that rear ended the thing.
Anyway, grabbed some 2" angle 1/8 thick, gonna mount it using the bolts that hold the hitch and gas tank skid in, plenty of threads for more plate.
Close up of the bolt plate, piece of scrap from one of the notched joints.
Mounted it up and stood on it, supported my weight, but had a bit more flex than I wanted. I want the spring to flex, not the mount.
Reinforced with some scrap then hung it up for paint. Propane torch to heat it up a bit and then some flat black rattle can.
Finished product.
And some mounted pics.
kg6mov is offline
post #100 of 383 Old 04-23-2013, 02:47 PM
PolkaPower
Attachment 614082
Attachment 614080
Attachment 614081
Attachment 614079
Finished product.
Attachment 614078
Attachment 614077
Attachment 614076
Attachment 614075
How does the hatch open? Just bend it out of the way?
PolkaPower is offline
post #101 of 383 Old 04-23-2013, 03:15 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Theres a quick release on top of the spring, you can see in the first picture. Pop the antenna off and the hatch clears the spring.
kg6mov is offline
post #102 of 383 Old 04-24-2013, 02:03 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
So I redesigned my bumper swapping bends for miters and cleaned it up a bit incorporating the winch mount.
Now I just have to figure out how to miter the pipe.
The wood cutting chop saw is down, and $200 on a metal chop isn't in the budget before the next wheeling trip. Freehanding it isn't gonna work, must be a better way.
I searched around and found this: http://www.metalgeek.com/static/cope.pcgi
It's designed for creating cope templates but if you set the offset to higher than the diameter (diameter 2) of the second pipe (like double) it will give you the template for a miter.
Cut out the edges (not the miter edge) I use a little super 77 adhesive to tack it on the pipe.
I tried using the sawzall to rough cut and grind it, tried using a cutting disk on the grinder. No dice. I just don't have a steady enough hand with the grinder to get good enough results. And the sawzall almost does more harm than good.
I think this would be a fine method if I had a bandsaw, or a lot more patience, but I don't.
So since we're trying stupid tricks, lets try the metal blade on the table saw.
Now to be clear, my table saw is not you're average table saw. It's a shopsmith Mark V tool. It's designed to be used as a lathe in addition to a table saw, drillpress, and disc sander, so it has a better built head bearing than your average table saw. And the most important part, it has a CV transmission that lets me adjust speed on the fly.
I did a test at around 3k rpm, which is a little slow, but things were looking good. I'll crank it all the way later and see if it works out.
Sometimes I get the feeling that they're watching, and they're laughing at me.
kg6mov is offline
post #103 of 383 Old 04-24-2013, 02:40 PM
riot1987
See if there is a band saw for sale on cl?
Build thread^^
riot1987 is offline
post #104 of 383 Old 04-24-2013, 02:45 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
I may be able to knick a porta band out of my grandfathers shop when I'm down in LA this weekend. My uncle is a pipe fitter and my grandfather was a welder/foreman all his life so they'll have some input.
kg6mov is offline
post #105 of 383 Old 04-24-2013, 02:53 PM
riot1987
Or get a heavy duty chop saw. We have one with an abrasive blade and it would cut that tube all day. Itd be cheaper and smaller than a band saw too. Those abrasive blades are cheaper than a metal one with the carbide teeth and ****. Look into it. Pawn shop?
Build thread^^
riot1987 is offline
build thread , v8
