N6MZV Build Thread (By kg6mov) - Page 14 - JeepForum.com
 3Likes
post #196 of 370 Old 07-10-2014, 09:02 PM
riot1987
I want those axles you son of a *****
Build thread^^
riot1987 is offline
post #197 of 370 Old 07-23-2014, 05:53 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
So I've had the front end poppy-clicky for a while. I figure the CV shafts are probably on their way out anyway so I stopped by the JY after work and found myself some U-joint shafts.
Now in the long run I'd rather have CV's especially with a full time case, but the green mafia brand don't last on the trail and the mopar stuff is way more than I want to put into a turdy.
So u-joint shafts it is. I was lucky enough to find a pair on a 96 ZJ that had good u-joints already.
Pulled the front end apart and found a surprise on the passenger side. This discoloration is normal right? Nothing to be worried about. Crap.
kg6mov is offline
post #198 of 370 Old 07-23-2014, 06:42 PM
iann32
I would check if the bearing's good and if it is i guess it would be fine lol.
iann32 is offline
post #199 of 370 Old 07-23-2014, 07:23 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, there's no play in it and it's not giving me **** so I'm not bothering to swap in one of my spares. Maybe when I do balljoints in a week or two I'll care, maybe not.
kg6mov is offline
post #200 of 370 Old 07-23-2014, 08:17 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Got around to replacing my oil pressure leaking unit.
The first one I got off amazon was missing a pin, so I grabbed one from the green mafia.
I think it might have been slightly off though.
So I ended up with one from the stealership, bugger.
Was doing some interior work so I ripped out the VIC and resoldered the pins, no more coolant sensor bull****.
Swapped in the radio from the niner (slightly newer model). Also took apart the steering wheel and hit all the buttons with contact cleaner.
Reprogrammed the steering wheel controls. Works great.
Added a hook for the microphone, works better than I thought it would.
kg6mov is offline
post #201 of 370 Old 07-24-2014, 07:55 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
oil pressure sensor only uses one pin
HighLonesome is offline
post #202 of 370 Old 07-24-2014, 02:47 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Weird, the one I pulled had two and the green mafia and dealership ones both had two. Maybe year break? Single pin one did work for ****.
kg6mov is offline
post #203 of 370 Old 07-24-2014, 03:26 PM
HighLonesome
yea must be the year break, I just did mine on my 95
post #204 of 370 Old 07-24-2014, 03:42 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Oreileys told me the two pin was for 96+. That's what I got for the 96 and it seems to work fine.
Sent from my iPhone 9 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
post #205 of 370 Old 07-24-2014, 07:14 PM
Scopez
1994 ZJ
So that's why my oil pressure is pegged at 80. used a 96+ one in a 94 ZJ. Fail....off to the store I go.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #206 of 370 Old 07-24-2014, 09:34 PM
MTBlue
I know how that feels
Dirt Deprived
MTBlue is offline
post #207 of 370 Old 07-24-2014, 09:44 PM
Scopez
1994 ZJ
Thought I could get by with just leaving it on the motor when I swapped...apparently not. Changing it out tomorrow.
Scopez is offline
post #208 of 370 Old 08-01-2014, 05:39 PM
iann32
Attachment 1496674
That discoloration is definitely normal.
Brand new wheel bearings that were just put on and both had the same discoloration. Its actually more a purple than brown.
iann32 is offline
post #209 of 370 Old 08-01-2014, 06:26 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Interesting, must be part of the manufacturing process and I just didn't notice it. Come to think of it, I did install that wheel bearing in the dark.
kg6mov is offline
post #210 of 370 Old 08-01-2014, 06:43 PM
iann32
ya i guess it must be. Unless i got defective bearings XD
iann32 is offline
build thread , v8
