N0 Brake Lights! - JeepForum.com
post #1 of 5 Old 07-27-2007, 07:18 AM Thread Starter
jeepster51
N0 Brake Lights!
1998 Grand Cherokee has no brake lights. Replaced the fuse under the dash and the light bulbs appear unbroken. Anyone gotr any advice? I'm thinking it's the brake light switch above the brake pedal.
jeepster51
jeepster51 is offline
post #2 of 5 Old 07-27-2007, 02:42 PM
merlinTec
merlinTec's Avatar
the next step would be to test the switch, was the fuse blown?
merlinTec is offline
post #3 of 5 Old 07-27-2007, 02:50 PM
ProductUser
Take a multi-meter or a 12 volt test light and ensure power is getting to the brake light connectors on the end of the wiring harness.
My tail lights went out, but the cause was due to the tail light assembly and not the switch, fuse or wire harness.
Just my 2 cents.
ProductUser
ProductUser is offline
post #4 of 5 Old 07-27-2007, 03:03 PM
merlinTec
merlinTec's Avatar
to help you test this
CAV CIRCUIT FUNCTION
1 L53 20BR STOP LAMP SWITCH SENSE
2 Z1 20BK GROUND
3 V32 20YL/RD SPEED CONTROL ON/OFF SWITCH SENSE
4 V30 20DB/LG SPEED CONTROL STOP LAMP SWITCH OUTPUT
5 L50 18WT/TN STOP LAMP SWITCH OUTPUT
6 L16 18RD/LG FUSED B(+)
regards,
merlin
post #5 of 5 Old 07-27-2007, 04:56 PM Thread Starter
jeepster51
Thanks for all the great advice!!
the fuse was not blown when i initially checked. so i changed out the brake light switch as suggested by merlintec and everything is now A-OK.
Jeepster51
Repaired leaking brake power booster, but now brake lights are on all the time MNWJ ZJ Grand Cherokee Forum 2 05-11-2009 07:59 AM
No brake lights when head lights are on sullivanpunk ZJ Grand Cherokee Forum 10 08-25-2008 05:44 PM
No Brake Lights when Running Lights are On jeepsta9000 ZJ Grand Cherokee Forum 9 06-24-2006 12:01 PM
Brake Lights - Backup Lights wont Turn off!! Ruffy ZJ Grand Cherokee Forum 2 07-12-2005 08:38 AM
