Mystery Front Brake Issue? - JeepForum.com
post #1 of 15 Old 11-10-2013, 08:08 PM Thread Starter
LeoSchultz
Hello,
I have a 98 Grand Cherokee Limited, 5.2. I have just replaced all the calipers, and the passenger side wheel bearing and hub assembly. When i drive it over 50 miles per hour, the front passenger side wheel feels like it is braking by itself.. WHAT could this be? This has been an issue for about 6 months now and Im out of things I can think of. Please any advise would be great!
LeoSchultz is offline
post #2 of 15 Old 11-10-2013, 08:21 PM
bigbill888
Bad tire? Front end way out of alignment? I've heard (never witnessed) of the rubber portion of the brake line coming apart inside and not allowing the brake fluid to retreat after releasing the brake.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 15 Old 11-10-2013, 08:26 PM
bigbill888
The little sliders where the brake pads rest develop a notch that shouldn't be there. Is yours so bad that the pad is forced against the rotor? I ground the "shoulders" of the grooves off in an effort to allow the pads to move back and forth unhindered.
All work well
post #4 of 15 Old 11-10-2013, 08:34 PM Thread Starter
LeoSchultz
I believe there is a notch, I thought it was susposed to be there I'll take a look tomorrow and see what I can do about it.
post #5 of 15 Old 11-11-2013, 04:58 AM
gearheadnick
If there is a notch, repairing it is relatively easy. Just fill in the notches with a welder and grind it flat. I've already done my rear brakes, just haven't gotten around to doing the front.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #6 of 15 Old 11-11-2013, 06:49 PM Thread Starter
LeoSchultz
I have another question: can I remove the front axle shaft to turn this into a two wheel drive temporarily? Or is there more I have to do?
post #7 of 15 Old 11-11-2013, 07:24 PM
JasonStebbins
Yes, but front drive shaft, not axle shaft. Sounds like a sticky caliper to me. Or collapsed brake line.
Poop
JasonStebbins is offline
post #8 of 15 Old 11-11-2013, 07:27 PM Thread Starter
LeoSchultz
A colasped brake line would cause this even after I have not pressed the brake for over 5 miles before hitting 50 mph?
post #9 of 15 Old 11-11-2013, 07:31 PM
JasonStebbins
Over time the rubber lines to the calipers develop a bubble that can intermittently stop flow. I say its a bad caliper still.
This happens randomly while driving even when not braking?
Poop
post #10 of 15 Old 11-11-2013, 07:35 PM Thread Starter
LeoSchultz
Yea. Its random. The brakes function normally otherwise. No other issues with the brakes.
post #11 of 15 Old 11-11-2013, 07:39 PM
JasonStebbins
Swap in a new caliper to rule it out. Cheap, fast and easy. Inspect the rubber line while your down there. I can't think of anything else that would make the pad drag on its own besides the grooves mentioned before.
Poop
post #12 of 15 Old 11-11-2013, 07:41 PM Thread Starter
LeoSchultz
Ok. Will definitely do that. Could a bad CV cause the same thing to happen? And IF I take out the front drive shaft, will that change the towing capacity?
post #13 of 15 Old 11-12-2013, 12:28 AM
JasonStebbins
If a CV actually broke apart, it could lock up the wheel, but you never mentioned that it seized completely. Sounds like a brake issue.
I don't see how that could affect towing capacity. But you do have all time 4wd with that transfer case, so don't drive off the road.
Why are you removing the front shaft anyway?
Poop
post #14 of 15 Old 11-12-2013, 07:15 AM Thread Starter
LeoSchultz
It was just a thought, I was wondering if you can.
post #15 of 15 Old 11-12-2013, 07:18 AM Thread Starter
LeoSchultz
And no, it has not seized up at all, just the grabbing issue. I need to find a welder and grinder so I can fix the groove and replace the rubber brake line and then we shall see what's going on.
