my zj will start and run but only for a couple seconds
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
hey
my 5.2L grand cherokee:confused will start and run but only for a few seconds im not sure of the problem ive tried grounding the purple and yellow wire and not sure what else to do if you have any suggestions they would be welcomed ![]()
83 cj7 with a 79 cj5 304 v8 2.5 inch suspension 31 10.50 15 and soa coming soon 96 grand cherokee 5.2 318 stock on 33 with a custom snorkle built not bought #116 |
#2 |
sounds like what mine does when the security is tripped, if I lock it with the remote and unlock it with the key it will not stay running until i lock it and unlock it with the remote again.
THE MORE MUD THE BETTER PEI JEEPERS MEMBER
#3 |
i dont exactaly have doors on it so im not sure but i tried the security ground and there were two purple and yellow wires do you know anything about that
#4 | ||
look for the purple wire with the yellow trace
Brian 95 ZJ, 5.2 V8,160,000 miles Colorado Jeep Club member Pi Quote:
#5 |
when you say yellow trace do you mean like a yellow stripe
#6 | ||
yep
http://www.jeepforum.com/forum/f13/how-disable-your-alarm-your-zj-483020/?highlight=security+system
#7 | |
#8 |
hey funny you say you took the doors off i just took mine off today but just hook the wires harnes to the door and unlock it with the key three times it will kill the alarm i had the same problem and never worked using the wire trick
#9 | |
so im not really sure about that but what if i put the doors on and then i took the doors back off do you think that would work![]()
#10 |
no it has to be tripped by the key
#11 |
any way to clean it out and can i do it with only the drivers door hooked up???
#12 |
bump...
#13 |
bump...still wonderin
gonna try to clean out the door harness today....??
#14 |
bump...
im still workin
#15 |
bump....haha
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
