my ZJ w/photos ~ build sheet ~ and progress... - Page 3 - JeepForum.com
post #31 of 114 Old 11-22-2008, 05:58 AM
Katesdad
Katesdad's Avatar
Interesting setup. Could have used airbags with the 1000 lbs of shingles I hauled yesterday. That switch does spark some interest. Your 2 wd will go alot of places with a rear locker.
Katesdad is offline
post #32 of 114 Old 11-23-2008, 06:09 PM Thread Starter
kali_jeep
Originally Posted by kali_jeep View Post
as to the locker...
would it be bad if i hit the switch to the ON position while, lets say, driving fast on the freeway?
anyone, please?
kali_jeep is offline
post #33 of 114 Old 11-23-2008, 07:30 PM
daufuskieraised
Well I have no experience with lockers, but I would think it could do some some major damage. I think you would hear it if you did it and it did damage.
1996 ZJ Laredo
1.75"BB, Monroe Shocks
Cheap Radioshack CB radio
Magnet antenna
daufuskieraised is offline
post #34 of 114 Old 11-23-2008, 07:38 PM
grandpapy
anyone, please?
if i'm not mistaken and i don't have one but from what i understand about lockers especially air, is you must be stopped and when you turn it would cause both wheels to lock and you wouldn't be able to turn almost at all, but since it's in the rear it would act like a spool and you would have to break the tires a bit when you turn. not good on the axle and especially if you have a 35c rear end i wouldn't use it unless you have too. is your ride a v8 and what years?
"hmmm. I would never imagine a jeep owner talking bad about them anyway....we all know they empty our pockets...yet they fill our hearts...I say great pay off." Nashmd454
grandpapy is offline
post #35 of 114 Old 11-23-2008, 07:57 PM Thread Starter
kali_jeep
I6 / 1995
i drove into some mud yesterday with one wheel and without the button stepped on the gas and the one wheel was spinning while the other wanted to grab the road, then with the button turned on i did the same and both wheels acted the same way and out the mud we went...
post #36 of 114 Old 11-23-2008, 08:08 PM
Mickey_D
Definitely a locker then. Nice upgrade!! Wish I had one in mine.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #37 of 114 Old 11-23-2008, 09:02 PM
sadass
Lockers should not be used on pavement. not your type anywhy. you have a selectable locker. and It will only make handling worse on wet pavement and add exccesive rear tire ware, not to mention a d35c is not set up to handle that appication well. and sure, a full time locker like power tracks lock-rite will ratch/override and alow for cornering to prevent what I have stated, but selectables do not! both axles are locked together and tires will not turn at differnt speeds when cornering. and as stated before MOST selectables will not allow you to engage above a certain speed. seriously, the only time you should use it on the road is if you cant make it without, i.e snow . off pavement no problem.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #38 of 114 Old 11-23-2008, 09:15 PM
tirus89
I dont understand the whole airbag switch with the PSI monitor. Airbags as suspension airbags or airbags as the ones that deploy in a car accident?
tirus89 is offline
post #39 of 114 Old 11-23-2008, 10:00 PM
JCZJ
suspension airbags...they sit inside the springs.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline
post #40 of 114 Old 11-23-2008, 10:04 PM Thread Starter
kali_jeep
reason i asked is because the swtich is right there next to the gear shifter and the passanger side, and if by accident the switch was hit i wanted to know what would happen, not me turning it ON on purspose for no reason....
suspension airbags to lift the back end while towing....
post #41 of 114 Old 11-23-2008, 10:30 PM
sadass
IF you are on the road and it happens, you probably wont even notice until you turn hard, like left or right on a street, or in a parking lot, you will feel the back wheels hopping and jerking as when you turn left lets say, your in board tire follows a shorter path , thus with an open diff it would allow left to turn at a slower rate, where a locker locks both sides together and the inboard tire will break traction and hopp due to the tourqe applied evenly to both tires, that is why you will ware the tires rapidly and it puts excess ware on the drive train. you will also notice that if you are on the skinny pedel and turn when it is wet you will have the *** end kick out, in stead of just one tire breaking loose as an open diff would, a locker they both will. bottom line is nothing detramental should happen. just turn it off as soon as you notice it, and you will ,like i said, turning.
sadass is offline
post #42 of 114 Old 11-23-2008, 10:41 PM Thread Starter
kali_jeep
cool, thanks...
i was going to make something to go over the switch so it can't be pressed by mistake... but haven't given too much thought to what it would be...
post #43 of 114 Old 11-24-2008, 12:01 AM
zippome
cool, thanks...
http://www.radioshack.com/product/in...ductId=2062493
how about this? thats what i would do
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline
post #44 of 114 Old 11-24-2008, 02:05 AM
sandman
it wont hurt anything. but to minamize tire wear and retain good street manners the locker shouldnt be enguaged on pavement.
1993 Jeep ZJ. 4.0
sandman is offline
post #45 of 114 Old 11-24-2008, 10:06 AM
gabrod72
After reading this thread it seems to there is too much concern about the locker engaging during some street driving. It is a concern because if it activates at the wrong time (say on a curved overpass in the rain) then you could end up having the rear end slip out a bit. If you can't compensate by counter-steering then you will be in big trouble.
I however would not worry about it.... just keep your hands away from the switch until you really need it. I've owned two auto lockers in the past and have not had any problems with them at all - even though they have locked up unexpectedly just like the situation above.
I had a full detroit in my discovery and now have a powertrax no slip in my ZJ. Both have worked phenomenally off road and were well behaved on road (except when you make hard turns or u-turns or back out of a parking spot while turning the wheel all the way.) Then you'll hear some wierd stuff from the detroit but the no-slip is much quiter. Anyway, enjoy the locker dude! If you have good traction tires for offroad - Like BFG mud terrains and a lift, you will likely be able to punish most un-locked 4x4s out there. My buddies are locked as am I and we have lots of fun messing around in 2WD... hell, we've gotten many open-diffed 4x4s out of mudholes and other obstacles in 2WD!!! Having a locker is a HUGE advantage and I'll take it in a 2WD rear end over an open-diffed 4x4 anyday. This is all hypothetical of course as in reality I would buy the 4x4 and within a week or two get the locker installed in it!! Happy wheeling in your 2WD... you'll be surprised at what your vehicle is capable of vs. open diffed 4x4s (provided that the driver you compete with is not too advanced of course.)
gabrod72 is offline
Got my build sheet! 97ZJMAN242 ZJ Grand Cherokee Forum 7 01-29-2009 11:57 AM
build sheet Dillonzj ZJ Grand Cherokee Forum 1 11-24-2007 10:07 AM
build sheet jeepster2000 ZJ Grand Cherokee Forum 3 07-21-2007 08:56 AM
Getting build sheet SteelBlue_WJ ZJ Grand Cherokee Forum 2 04-09-2006 08:41 AM
Got my Build Sheet! O Holy P ZJ Grand Cherokee Forum 7 04-07-2005 08:12 PM
