My ZJ is dead in the water..... - JeepForum.com
post #1 of 13 Old 05-24-2013, 11:12 AM Thread Starter
BeRight
Its simple, I was driving and as I was approaching a stop sign I noticed my Jeep starting to "stall" (its an automatic) and that was the end of it. I thought my fuel pump went out, so I replaced that. It turns over but wont start. Check to make sure I have fuel and correct pressure. My spark plugs are all sparking. Distributor cap is on time. Relays all still working. It turns and turns and turns but wont start. The only possibility I can think of is that the timing chain somehow jumped teeth. I got nothing guys, any insight?
BeRight is offline
post #2 of 13 Old 05-24-2013, 11:41 AM
dellis
2005 WK
dellis is offline
post #3 of 13 Old 05-24-2013, 04:30 PM
Rich93ZJ
crank position sensor
Rich93ZJ is offline
post #4 of 13 Old 05-24-2013, 04:38 PM
just_urd
^My first thought^. Diagnose from easiest to hardest in relation to the problem. At least you've got a fresh fuel pump...
just_urd is offline
post #5 of 13 Old 05-24-2013, 05:33 PM
rooster51
x3.
Terry
rooster51 is offline
post #6 of 13 Old 05-24-2013, 07:54 PM
ZeeJay1997
Originally Posted by dellis View Post
^^^x2
ZeeJay1997 is offline
post #7 of 13 Old 05-24-2013, 10:06 PM
Rich93ZJ
Almost forgot. MOPAR ONLY!!!!!!!!!!. Don't use the cheap autoparts store Chinese crap.
Rich93ZJ is offline
post #8 of 13 Old 06-06-2013, 07:26 AM Thread Starter
BeRight
The crank position sensor should set a dtc code and I've got none.
BeRight is offline
post #9 of 13 Old 06-06-2013, 07:44 AM Thread Starter
BeRight
Heres my report from the dirty dozen.....
The Brain.... Its worth a shot just havent had time yet
Grounds....worth a try
PDC....checked and cleared
Battery and Cables........needs a good cleaning
Fuel quality....looks and smells good
Fuel Pressure......at spec
Secondary Ignition... Fine
Connection....It doesnt run so I cant try it. But it wasnt running poorly before it dies except for the 2 minutes prior.
Wiring.....Anything like that should set a check engine light
Throttle body....Shouldnt cause it to completly not run
vaccuum leaks...none
Restricted Exhaust....cut exhaust before the cadalytic converter...no change
But this list gives me other things to check as well
BeRight is offline
post #10 of 13 Old 06-06-2013, 08:07 AM
dellis
2005 WK
I think you are giving your Check Engine Light too much credit ... faulty wiring will not always set a CEL. Also, I think most people on this forum who have had problems with weak/failing Crankcase Position Sensors did not have a CEL.
The last MOPAR part I received had stamped in big bold letters, "MADE IN CHINA". You cannot escape ...
dellis is offline
post #11 of 13 Old 06-06-2013, 12:20 PM
dusterdude
Not always,mine didnt
dusterdude is offline
post #12 of 13 Old 06-06-2013, 04:10 PM
ZeeJay1997
x2
post #13 of 13 Old 06-06-2013, 04:12 PM
riot1987
Sounds like similar symptoms of when my cps went out
Build thread^^
riot1987 is offline
dead , fuel pump , mystery , timing chain , zj
