my wj has a squeak - JeepForum.com
post #1 of 10 Old 03-31-2006, 12:17 AM Thread Starter
BlueIceDragon
my wj has a squeak
my 02 se has a squeak/squeal in the right front tire vicinity
i happens when i go about 20mph and gets increasingly louder the faster i go
any one have ideas as to what it would be
any help will be appreciated
Chris
02 Dark Blue WJ I6 SE
nothing yet
future plans: 2" BB, 265/75/16's, grille guard with a couple of lights on it
just for fun
BlueIceDragon is offline
post #2 of 10 Old 03-31-2006, 12:22 AM
Briandl
Sounds more like a squeal...
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #3 of 10 Old 03-31-2006, 01:08 AM Thread Starter
BlueIceDragon
ok so its a squeal
what is it
Chris
nothing yet
just for fun
post #4 of 10 Old 03-31-2006, 01:51 AM
02jeepGCL
You might get more help if you could explain a little more. Does it gradually build up or is it sudden @ 20mph? Does it start once the trans shifts out of 1st? IIRC I saw something a/b certain 02s having caliper problems or something to that effect.. Sound anything like bad brakes? Does it change when you turn? I'm not telling you to answer that stuff.. just ideas to explain it better. Wish I was a mechanic.. *shrugs*
02jeepGCL is offline
post #5 of 10 Old 03-31-2006, 05:15 AM
Turbonut
When you hear the noise, keep up the speed and press the brake pedal slightly with your left foot to see if it's in the brake system e.g. pad. Also check pads to be certain they are not worn. Some pads came with wear sensors. Nothing more than a strip of metal, which will contact the rotor when the pad wears down to unsafe levels and if the rotor has minimal runout, the strip could make contact every revolution.
Turbonut is offline
post #6 of 10 Old 03-31-2006, 09:50 AM Thread Starter
BlueIceDragon
i tried the brake thing it didnt change
its not right at 1st gear
it is rather sudden then gradually increasing with speed
it doesnt get worse when turning
thanks for the replies
Chris
nothing yet
just for fun
post #7 of 10 Old 03-31-2006, 06:37 PM Thread Starter
BlueIceDragon
no one has any idea?
Chris
nothing yet
just for fun
post #8 of 10 Old 01-13-2008, 04:24 PM
flat tire
Did anyone ever figure out what caused this......I have the same problem on my 02 Overland?
flat tire is offline
post #9 of 10 Old 01-13-2008, 04:27 PM
Dillonzj
WD-40 should do the trick
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
Dillonzj is offline
post #10 of 10 Old 01-14-2008, 08:13 AM
flat tire
tryed that.....didn't change
Squeak squeak goes the jeep.. -Joe- ZJ Grand Cherokee Forum 13 06-04-2013 07:30 PM
*squeak*squeak* 97DCZJ ZJ Grand Cherokee Forum 1 06-11-2009 09:27 AM
94 ZJ has a squeak NEp8ntballer ZJ Grand Cherokee Forum 14 04-28-2008 07:08 PM
Squeak! Squeak! Squeak! KDH ZJ Grand Cherokee Forum 6 03-04-2007 11:44 PM
Squeak Daveeycrocket ZJ Grand Cherokee Forum 3 12-20-2004 12:47 PM
