My turn for an overheating problem! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My turn for an overheating problem!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-10-2013, 07:40 PM   #1
SCZJ
1994 ZJ
Cranked the jeep this morning let it warm up like always. Let it run maybe 5-6 mins. Got in and cool air was blowing out of the vents with the heat on. Also noticed it was getting a tad above 200 degrees, which is normal once I'm on the road, but not when it's only been running a few minutes!
After I got on the road hot air started coming out. As I got close to work I noticed the temp hand slowly moving over to 260. It would get to the red and then go back over toward 200. Did this a few times.
I'll let it sit all weekend and work on it Monday. Sound like a stuck thermostat?
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc... Just another cookie cutter ZJ.
SCZJ is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 08:22 PM   #2
JasonStebbins
Check the coolant level.
Examine the fan clutch.
Check the water pump for leakage.
Ever replace the radiator cap?
Replace the thermostat.
Poop
JasonStebbins is offline   Reply With Quote Quick reply to this message
Unread 05-14-2013, 04:42 PM   #3
SCZJ
1994 ZJ
@JasonStebbins: Thanks for the advice. The coolant level was low due to the leak. The fan clutch seemed to be fine; no free spinning, plenty of resistance. It ended up being the water pump. The bearings were shot!
