Quantcast My tire dilemma - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > My tire dilemma
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 04-30-2006, 07:00 PM   #1
rrubio
My tire dilemma
Going to get tires very soon.I want to get 33's but being having my rear-end locked is not a wise choice.But I also plan on upgrading my axle within a year.If I do decide to get 33's now I will not be able to do any of the difficult trails in MOAB this June.But I also don't want to wait another two to three yearss to get 33's either.Kim says stick with 32's and wait till they wear out to get 33's so we can continue to do fun trails.She does not like doing easy trails when im the driver.Plus she wants(her being the driver) to do Poison Spider at GSW.
rrubio is offline   Reply With Quote
Old 04-30-2006, 07:36 PM   #2
10achik
I ate what?
10achik's Avatar
To be honest, I'm not planning on going to a 33's until I get the 5.5" springs from Iron Rock, the D44 should be plenty strong for 33's. You have the D35 in the rear right? I see what you mean by needing to switch the axle with 33's and being locked. You definately don't want to break anything. You could look around for a cheap used set with some good tread left to get you by until you can change the axle.
Right now I'm rubbing the upper fenderwell pretty good at full flex as it is with 32's. I could only imagine what I'd do if I went up to 33's.
Also if your going to Moab, you know your going to want to do the fun stuff.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85)
2006 Pontiac G6 GTP - (her's)
2001 Dodge Ram 1500 - CAI, Soft 8's, 31's
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Old 04-30-2006, 07:41 PM   #3
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Ramon,
I'm looking to upgrade tires also. However, the only thing keeping you from doing harder lines was a spotter and your driver wanting to take the time to try it.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 04-30-2006, 07:54 PM   #4
rrubio
Damit guys.I want to hear get the 33's from you guys.. I don't want to get a set of used 32's.Ive done alot of trails in MOAB and I know being locked and 33's with the D35 I would definetly break an axle.
Old 04-30-2006, 07:58 PM   #5
Phil Gerard
Break it, Fix It!
Phil Gerard's Avatar
Get the 33s! What are ya waiting for! Get Em!!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline   Reply With Quote
Old 04-30-2006, 08:03 PM   #6
10achik
I ate what?
10achik's Avatar
Sounds like you need to order the 33's and go get that axle now then...
Did that help?
Ken
Old 04-30-2006, 08:13 PM   #7
Woody
Retired back to Bowties
Woody's Avatar
1985
Get the 33's and a spare set of axle shafts and you should be set.
I won't tell you what size tires I fit today. I'll make another thread for it.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Old 04-30-2006, 08:17 PM   #8
zaq123
1941 MK Compass
Get 33s. What do you have, D44a? It should be fine with 33's
zaq123 is offline   Reply With Quote
Old 04-30-2006, 08:23 PM   #9
rrubio
If I had the D44a I would not even give it a second thought.I have an extra set of spare axles for my D35.Upgrading my axle is not going to be cheap.
Old 04-30-2006, 08:31 PM   #10
BlaineWasHere
Addicted to Boost.
BlaineWasHere's Avatar
Get 33's and keep your eyes pealed for a 44a... bolt in replacement good for 33's locked.
2007 VW GTI
BlaineWasHere is offline   Reply With Quote
Old 04-30-2006, 08:38 PM   #11
Woody
Woody's Avatar
1985
Ramon, I think you'll find that unless you are really hard on the gas pedal, you won't break the D35 all that often. The ones I've seen go, only do so when the driver decides to put the throttle to the floor for no reason but to show off.
Woody
Old 04-30-2006, 08:47 PM   #12
rrubio
Woody you have a good point.I don't wheel like that at all. I take it nice and slow unless I need to give it some gas.
Blaine im keeping my eyes open for a WJ's 44 but no luck yet.They are still expensive even at the local junk yard.
Old 04-30-2006, 08:56 PM   #13
AgitatedPancake
Frobot Fabrication
AgitatedPancake's Avatar
get the 33"s! They are a blast! Tested mine out today, flexed 'er pretty good too...didnt rub bad at all! (Though I removed my washer fluid reservoir, and I dont have the original bumper). Now for the taunting...
Pretty good flex...
Hey...I dont think it was even rubbing here, but it was close lol.
Look at what you could be doing...mmmm fun.
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake is offline   Reply With Quote
Old 04-30-2006, 09:04 PM   #14
rrubio
I took out my windshield water resevior along time ago,well I did not do it my tire was the one who took it out
Old 04-30-2006, 09:09 PM   #15
AgitatedPancake
Frobot Fabrication
Haha, my tire took out hte pumps and foglights. I think it was telling me something. Trim fenders, make a bumper and your set! (then theres that little axle thing...*cough*)
Glock Forum
