is my speedodo off????????? - JeepForum.com
post #1 of 3 Old 06-24-2004, 03:12 PM Thread Starter
LBX2G
I kno when change the tires out on ur jeep or any car for that matter that is affects ur speedodometer. BUT see i have have 275/45/20 on my jeep and when i go by those speed ditecting devices it reads the same as my speedodometer. I was wonder is there something or am i seeing things
-if u need more info let me kno
- thnx in advance
*******************Disclaimer********************* ********
when I make a post. I am only posting my opioion and my experince and what I have learned from it. I am not claiming to be no kind of all knowing god. I am not trying to shove my work or my experince into no ones face. If it helps you in anyway then you are welcomed if it does not....well sorry that I can not be of somekind of assistance.
******************Disclaimer**********************
LBX2G is offline
post #2 of 3 Old 06-24-2004, 03:56 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
- thnx in advance
If those tire size numbers are correct, your tire is a 29 3/4 inch diameter, only about an inch bigger than stock. You shouldn't see a significant change in your speed-oh.
Doug
((275/25.4)*.45)*2+20 = tire diameter
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 3 Old 06-30-2004, 03:29 AM Thread Starter
LBX2G
thanx man .................................................. .
LBX2G is offline
